Fibre Extra speed with low IP profile?
- Fibre Extra speed with low IP profile?
2 weeks ago
I'm hoping someone more tech savvy than me can steer me in the right direction!
I recently did a BT wholesale speed test, and found that my line IP profile is 20Mbps. My download speed is 21.6Mbps. My Plusnet contract for Fibre Extra shows an estimated speed of 31-47Mbps, with a minimum guaranteed speed of 27.3Mbps. Strangely, it also shows my current speed as 21.6Mbps.
I raised a fault report on the Plusnet website, querying this, and got a quick email reply on the 1 April at 9:14am, asking me to send BT wholesale results and update in ticket at link https://www.plus.net/wizard/. I emailed them back at support@plus.net, to say that this link doesn't seem to connect me with any ticket I've raised.
At 11.11pm they emailed me back to say that as I couldn't supply the speed test information, they had closed the ticket. Well, thanks for that!
Some people may think that I'm getting the run-around, but you won't hear me say that!
I know IP throttling doesn't exist, but if I was a more suspicious person?
Any advice from someone with a bit of knowledge of these things would be gratefully received
Re: Fibre Extra speed with low IP profile?
2 weeks ago
@JenV A low IP profile and also ‘current line speed’ would be a symptom of your sync speed being slow.
Support@plus.net isn’t an email address you can email, it’s an address you’d get notifications from. Tickets stay open for 14 days before closing so I suspect you’ve accidentally closed the ticket online? Check the ticket by going here https://www.plus.net/wizard/?p=search
In any case try plugging your router into the test socket explained here https://community.plus.net/t5/Library/Testing-From-The-Master-Socket/ba-p/1322242 and if your speed’s still slow then it’s probably worth raising a new fault ticket at faults.plus.net
2 weeks ago
2 weeks ago
2 weeks ago
Plusnet can’t close fault tickets you raise due to system functionality. It could be possible you’ve accidentally closed the ticket online. If you use the above ticket link you’ll be able to see the closed ticket to check.
2 weeks ago
2 weeks ago
The service notice could be what was triggered when the fault ticket closed. Check the tickets themselves...
Either way glad to see you’ve got a new one raised
