Fibre Extra lower than expected upload speed
Intrepitd3D
According to BT Wholesale the upload speed on my line should be -20Mb/s.
However, its never more than about 9Mb/s
I upgraded to Fibre Extra specifically because i need a high upload speed, at £40 a month it is expensive.
So i would like the speed BT wholesale say my line is capable of, please.
Fixes: 219
Re: Fibre Extra lower than expected upload speed
The BTWholesale speedtest will always show the maximum possible upload speed profile for the product your on rather then your sync speed.
Your estimated upload speed is between 15.4 and 10.5mbps however this refers to the sync speed and not your actual throughput.
 Matthew Wheeler
Intrepitd3D
Thanks for the reply Smiley , please explain why my Throughput would be less than my Sync Speed.
Fixes: 219
This page here explains that for you.
 Matthew Wheeler
