Fibre Extra Upgrade ... Same Speed
Digeeboy
Had an email this morning saying the order has been completed.
Have rebooted the router .... but my test results are still 38Mb/s download and 13.5Mb/s upload
Can you check the order has in fact completed?
Thank You
7 REPLIES 7
adamwalker
Fixes: 221
Re: Fibre Extra Upgrade ... Same Speed
Hi there, I've just checked the account and both the order with our suppliers and the necessary changes to our systems have gone ahead as expected to allow the upgrade.
If things still haven't changed from your point of view I'd try rebooting the router again then testing speeds over a wired connection to the router.
 Adam Walker
goncalop
Hi. I've had the same experience - Received e-mail but no speed upgrades.
Been running tests through my Google Router remotely and still getting the old speed (30-37)
Could you confirm my order went through?
Regards
Digeeboy
Hi Adam
I rebooted the router again and over a wired connection I'm getting 53.8Mb download and 13.8Mb upload
So the upgrade has gone through.  But is this the best speeds I can expect?
SammyM
Fixes: 96
Hello @goncalop,
Thanks for getting in touch. We are sorry to hear your speed has not increased and would be happy to look into this for you.
We will respond on your other thread here shortly.
 Sammy M - Sheffield Team
SammyM
Fixes: 96
Hello @Digeeboy,
Thanks for getting in touch, as your speed has upgraded today to the fibre extra we would advise to keep an eye on your connection for a few day to see if the speed improves.
Please let us know how you get on.
Digeeboy
My speeds have changed a little over the last few days ... now getting 50.2Mb download and 18.7Mb upload.
Does seem a little low on the download side.
Could you do a line check from your end?
Fixes: 1,600
I've tested your line today and while we're not finding a definitive cause for the slow speeds you're experiencing, your router is in sync at only 56.5mbps which is below where we'd expect them to be of at least 65.5mbps.
Could you try the steps Here and if you don't see an improvement, please report a fault to us at http://faults.plus.net
Let us know how this goes.
