Fibre Extra Unlimited
- Fibre Extra Unlimited
23-05-2017 7:51 PM
Currently I'm using a Billion 8800NL R2 router . I tried a recync last night but it didn't get above 39mb. It seems I'm stuck on around 39mb and not the estimated speed of 44-58mb.
Thanks.
Re: Fibre Extra Unlimited
23-05-2017 8:00 PM
Hi there, first of all a warm welcome to the community forums.
Sorry to hear you're having speed issues.
Testing your line is detecting a possible external fault...
Main Fault Location | LN |
Sync Status | In Sync |
Downstream Speed | 37.9 Mbps |
Upstream Speed | 7.0 Mbps |
I've raised this through to our suppliers now, and also created this ticket
We'll provide an update for you tomorrow.
23-05-2017 8:09 PM
23-05-2017 8:11 PM
24-05-2017 8:40 PM
Thanks for your patience @Twister1264 It looks like your speeds haven't improved following the engineer investigation today. We're not able to identify the cause of your slow speeds now as the line tests are passing.
It's likely we'll need to arrange another engineer, but this time it'll be an appointment we'll have to book. Before we do that, I'd advise to try plugging your router into the test socket if you can. This helps rule out internal wiring.
Explained here
Let us know how you get on.
26-05-2017 5:26 PM
The router is plugged into the test socket. I've tried three different routers and the download speeds do not go above 40mb.
I've noticed the interleaver level depth is set at 1 and the INP (DMT symbol )stuck at 0 on both download and upload.
I've also noticed I've been warned if there isn't a fault with the line then I'm liable for a charge.
Did the IP profile get reset when I switched over? Seems I'm stuck on under 40mb even though I'm paying for a higher speed service. Disappointing.
29-05-2017 8:51 AM
Sorry to hear an engineer arrived unannounced.
In fairness, we raised this as an external fault. On occasion, if an engineer feels that they require access, they would try to contact the end user first whilst on site instead of passing it back to us to arrange an appointment which can delay things.
Testing your line, I'm seeing your router still in sync below your estimates...
Downstream Speed | 39.8 Mbps |
As I'm not able to detect a fault, the next step would be to arrange an appointment.
If you reply to the open ticket on your account here we'll get the engineer booked in for you.
