Fibre Extra Speed
Rappers
Fibre Extra Speed
Upgraded on Monday and was getting around 70Mbps, then from Wednesday only averaging 35Mbps, not happy with this and have tried everything to speed it up. Should they have supplied me with the new Hub One faster router?
Terranova667
Re: Fibre Extra Speed
Hi it would make no difference all fibre based modem / routers handle speeds up to the max 80Mb as indicated by you getting 70Mb for a couple of days.
This sounds like you may have a fault that needs reporting and fixing.
Manny7860
For all ADSL and WBC Fibre to the Cabinet (FTTC) services, the stable line rate will be determined during the first 10 days of service usage."
Excellent!
Browni
Aspiring Hero
Fixes: 47
@Manny7860 don't believe everything you read! That doesn't apply to FTTC even though it is present on BT's site.
eta DLM on FTTC
I must have been really bad in a previous life as this was my 3rd ISP in a row that used lithium.
Now you're stuck with me because my new ISP doesn't run a forum Cheesy
Rappers
Plusnet,what is your opinion on this..?
Fixes: 35
Some actual figures might be more useful. What are your expected speeds on the DSL checker?
And what are your actual speeds reported on the Helpdesk page from the router?
Do you have a modern VDSL faceplate, and are you plugged into your master socket?
Fixes: 508
Hi there. Testing your line isn't showing any issues.
Main Fault Location OK
Sync Status In Sync
Downstream Speed 80.0 Mbps
Upstream Speed 20.0 Mbps
Voice Line Test Result Pass
Are your devices connected over WiFi or using an ethernet cable?
