Fibre Extra - How long does it take?
- Fibre Extra - How long does it take?
28-08-2015 4:24 PM
Thanks in advance.
Re: Fibre Extra - How long does it take?
28-08-2015 4:34 PM
The ASA imo should of ruled against ISP's Describing FTTC as fibre
28-08-2015 4:36 PM
28-08-2015 4:48 PM
http://speedtest.btwholesale.com/
28-08-2015 6:04 PM
If it's a quick change I'll do it now.
Thanks for the help.
EDIT: Just made the change. It actually says I'll move to it after my next bill..which would suck seeing as I literally paid my August bill yesterday.
28-08-2015 7:40 PM
29-08-2015 10:27 AM
03-09-2015 5:30 PM
Can this be looked into pretty please?
dick:quote
04-09-2015 4:53 PM
04-09-2015 10:31 PM
I thought I mentioned it yesterday but it appears not...I've actually been rebooting my router and modem after getting home from work since requesting the upgrade.
If it turns out that my line can't support the 80 Mbps profile then I may as well go back to my original package and save the extra fiver. But I'd really like more speed if my line supports it.
05-09-2015 10:54 AM
have you checked to see how the profile is set at plusnets end you can find it here https://portal.plus.net/my.html?action=data_transfer_speed
the current line speed should be more or less equal to the BT IP profile if it's not then something is wrong at plusnets end preventing you from getting the full speed the line can do.
as a side note don't keep rebooting the modem it can cause DLM to see that as the line not being stable and add interleaving, banding or both reducing speed you only need reboot the router if needs be.
05-09-2015 1:50 PM
05-09-2015 3:14 PM
06-09-2015 12:32 AM
06-09-2015 11:28 AM
