Fibre Extra - Can't connect 2.4ghz video doorbell
Mrpnmiller
Hi All, help needed please.
We have recently upgraded to the Fibre Extra Broadband with Plusnet.
Upon setting up the service we noticed our video doorbell stopped working - the device only works on 2.4ghz.
Checking the router settings it appears all devices are defaulting to the 5ghz option. Therefore, we wanted to seek guidance on how we can arrange for our video doorbell to be set up on 2.4ghz without impacting other devices using the 5ghz option?
4 REPLIES 4
BrightonRock
Fixes: 8
Re: Fibre Extra - Can't connect 2.4ghz video doorbell
Welcome to the Forum @Mrpnmiller
Which router are you using? A Plusnet Hub One with a big blue light on the front?
If it is that, as you have found out, it offers connections on 2 frequencies. By default they have the same ID and the advice is to give them different IDs, See https://community.plus.net/t5/My-Router/Devices-stop-working-on-5-GHz-connection-Wifi-drops/m-p/1395...for how to do it.
I don't know whether this will solve your problem, but it is a worthwhile first step.
Mrpnmiller
Thanks @BrightonRock
Thats correct we are using the Hub One router.
Is the a reason why the name change should be applied to the 5ghz network and not the 2.4ghz?
PeeGee
The requirement is to have different names - change whichever you prefer.
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
Mrpnmiller
Thanks @PeeGee we will give this a try.
Many thanks.
