Fibre Extra (24 hour upgrade?)
- Fibre Extra (24 hour upgrade?)
04-05-2015 7:36 PM
Hi Plusnet,
Currently I'm on your 38mb fibre option getting 37.5 down and 17.5 up, I'm interested in upgrading again depending on the speeds I will get in the extra package.
Would it be possible to get a temporary (24 hours or so) upgrade some time to test/check my speeds.
Message 1 of 3
(610 Views)
2 REPLIES 2
Re: Fibre Extra (24 hour upgrade?)
05-05-2015 9:07 AM
Either one of the DCT guys will be able to tell you your speed, or you can find out yourself by running the BT Speed Test http://speedtest.btwholesale.com/ and Further Diagnostics - look for the IP Profile.
Message 2 of 3
(335 Views)
05-05-2015 9:26 AM
Message 3 of 3
(335 Views)
