Fibre - Down again - Sync on the line but no authentication!
transmission1
Yet again I'm having the same problem that occurred last week.
My Fibre line is up and synced to the local cabinet with normal values but plusnet cannot authenticate me.
This is becoming a real problem especially when away from home and nothing locally can resolve it as there is nothing wrong with the line.
Can someone at plusnet please explain why authentication problems are occurring? Is this a general problem. No end of rebooting fixes this. Do I just have to sit it out until something is kicked at the other end of the system? I Put a support request in but hours later still no reply...
Thanks,
Simon
Fixes: 385
Re: Fibre - Down again - Sync on the line but no authentication!
Sorry to hear you're having problems Simon
It looks like things are back up now?
My tests haven't identified the cause of that. Apologies for the inconvenience caused.
transmission1
Hi Anoush
Thanks for getting back to me. Yes the authentication came back up again as your graph shows but it's been up and down another two or three times since. The strange thing is that the line is staying up and Sync is fine but the authentication drops out. Any ideas what can cause that? Is it a plusnet radius failure? If the line is stable then what is going on?
Simon
Fixes: 385
Hi Simon,
My tests haven't detected any possible causes of that. It could be due to anything from your router to the exchange.
Fingers crossed it doesn't happen again
