Fibre Disconnecting (almost daily).
Recently (last two weeks) my fibre connection has been dropping at random times of the day. Most recently was today at 1500, a copy of the router logs for the period is below.
During the outage the router lights go to orange, the B light flashes until it reconnects. The router is plugged into the master socket, no other devices are plugged in to the socket.
any assistance identifying if this is a router or BT line issue would be appreciated.
15:01:57, 22 Dec.
(2761952.270000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
15:01:57, 22 Dec.
(2761952.270000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
15:01:54, 22 Dec.
(2761949.500000) WAN operating mode is VDSL
15:01:54, 22 Dec.
(2761949.500000) Last WAN operating mode was VDSL
15:01:52, 22 Dec.
(2761947.360000) PPP IPCP Receive Configuration ACK
15:01:52, 22 Dec.
(2761947.350000) PPP IPCP Send Configuration Request
15:01:52, 22 Dec.
(2761947.340000) PPP IPCP Receive Configuration NAK
15:01:52, 22 Dec.
(2761947.330000) PPP IPCP Send Configuration ACK
15:01:52, 22 Dec.
(2761947.330000) PPP IPCP Receive Configuration Request
15:01:52, 22 Dec.
(2761947.300000) PPP IPCP Send Configuration Request
15:01:50, 22 Dec.
(2761945.380000) PPPoE is up - Down Rate=59927Kbps, Up Rate=18979Kbps; SNR Margin Down=9.7dB, Up=9.2dB
15:01:50, 22 Dec.
(2761945.360000) CHAP authentication successful
15:01:50, 22 Dec.
(2761945.320000) CHAP Receive Challenge
15:01:50, 22 Dec.
(2761945.320000) Starting CHAP authentication with peer
15:01:50, 22 Dec.
(2761945.320000) PPP LCP Receive Configuration ACK
15:01:50, 22 Dec.
(2761945.310000) PPP LCP Send Configuration Request
15:01:50, 22 Dec.
(2761945.310000) PPP LCP Receive Configuration Reject
15:01:50, 22 Dec.
(2761945.310000) PPP LCP Send Configuration ACK
15:01:50, 22 Dec.
(2761945.300000) PPP LCP Send Configuration Request
15:01:38, 22 Dec.
(2761933.340000) Lease for IP 192.168.1.82 expired. MAC: 54:e0:19:14:36:29, host name: Ring- 143629
15:01:38, 22 Dec.
ath10: STA 54:e0:19:14:36:29 IEEE 802.11: Client disassociated
15:00:58, 22 Dec.
(2761893.170000) PTM over DSL is up
14:58:59, 22 Dec.
(2761774.150000) CWMP: session closed due to error: Could not resolve host
14:58:59, 22 Dec.
(2761774.140000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
14:58:59, 22 Dec.
(2761774.130000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
14:58:29, 22 Dec.
(2761743.810000) CWMP: session closed due to error: Could not resolve host
14:58:29, 22 Dec.
(2761743.760000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
14:58:29, 22 Dec.
(2761743.760000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
14:58:28, 22 Dec.
(2761743.410000) CWMP: Initializing transaction for event code 4 VALUE CHANGE
14:58:26, 22 Dec.
(2761740.810000) PTM over DSL is down after 535 minutes uptime
14:58:26, 22 Dec.
(2761740.810000) PPPoE is down after 534 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 7 - Down)]
14:58:22, 22 Dec.
(2761737.350000) PPP LCP Send Termination Request [User request]
