Fibre Broadband
callinghall73ey
Fibre Broadband
My broadband has been extremely slow recently, can someone help out
  FAQ
1. Downstream Test: -provides background information.
  Download Speed   6.15 Mbps     0 Mbps 14.73 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 6.15 Mbps
 For your connection, the acceptable range of speedsis 10.31 Mbps-14.73 Mbps .
 Additional Information:
 IP Profile for your line is - 14.73 Mbps
  Upload Speed   0.63 Mbps     0 Mbps 10 Mbps
Upload speed achieved during the test was - 0.63Mbps
 Upstream Rate IP profile on your line is - 10 Mbps
6 REPLIES 6
BD
Fixes: 86
Re: Fibre Broadband
Hi @callinghall73ey, I'm sorry to hear you're having speed issues as of recent. I can see when testing your speeds they look to have certainly dropped recently and seeing you've had a line fault recently I'd imagine due to that. Today we are seeing 15.2Mbps download getting to the router however so I'd recommend re-testing your side to see if they've improved.
Let us know how they're looking today.
 Ben Devine
 Plusnet Help Team - Sheffield
callinghall73ey
Re: Fibre Broadband
Hello
Just ran again and got the results below it is more but I am sitting right beside my router
FAQ
Results Image not loaded
  Download Speed
  11.36 Mbps
0 Mbps 14.73 Mbps
 Download speedachieved during the test was - 11.36 Mbps
  Upload Speed
  0.79 Mbps
0 Mbps 10 Mbps
Upload speed achieved during the test was - 0.79Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
Please visit the FAQ if you are unable to understand the test results
callinghall73ey
Re: Fibre Broadband
just ran again from a different part of the house and only  as below, definitely not right
Broadband Speed Test Result
Download Speed (Mbps): 7.01
Upload Speed (Mbps) : 0.79
Ping Latency (ms): 31
EmilyD
Fixes: 111
Re: Fibre Broadband
I'm sorry to hear that you're still experiencing problems. I've tested your line but the test hasn't picked up any faults from here and indicates that it's currently syncing at 15.2mbps, which is within the line's estimates of 11.7 - 20mbps.
So that we can determine the best next steps for you, please can you confirm whether this issue is solely affecting wireless connections or if wired connections are affected too?
GEA Test Detail
Circuit ID NA Service ID BBEUXXXXXXXX
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 15.2 Mbps
Upstream Speed 0.5 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Cross Talk Detected
Estimated Line Length In Metres 1747.9
Upstream Rate Assessment Good
Downstream Rate Assessment Good
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
DP Type External
Profile Name 0.128M-40M Downstream, Interleaving Low - 0.128M-10M Upstream, Error Protection Off
Time Stamp 2019-10-03T11:15:00
Parameters MIN MAX AVG
Down Stream Line Rate 9.2 Mbps 17.9 Mbps 14.2 Mbps
Up Stream Line Rate 0.5 Mbps 0.5 Mbps 0.5 Mbps
Up Time 0.0 Sec 900.0 Sec 876.6 Sec
Retrains 0.0 6.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2019-10-16T10:47:55.953+01:00 2019-10-16T11:02:55.953+01:00
Ingress Code Violation 0 0
Egress Code Violation 0 0
Errored Seconds 0 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
 Emily D
callinghall73ey
Re: Fibre Broadband
Hello
Only wireless connections, it’s not been great since I upgraded to fibre and the new router
Fixes: 1,290
Re: Fibre Broadband
Thanks for getting back to us @callinghall73ey
Ideally we'd need to narrow down where the issue may lie by asking you to try a wired connection, do you have a laptop or computer or do you just use mobile devices such as phones and tablets?
If you don't or you've tried that and your speeds are OK that way, I'd recommend trying the steps in the post Here and also in the blog post Here to try to improve the wireless signal.
If your speeds are still slow on a wired connection, is your router connected into the master telephone socket? If you're unsure what it looks like, this post should help.
Finally if your speeds are slow on a wired connection and you're in the master socket I'd recommend raising a fault to us at http://faults.plus.net so we can arrange a broadband engineer to visit and investigate further.
