Fibre Broadband speed has dropped big time?
- Fibre Broadband speed has dropped big time?
02-08-2016 1:28 PM - edited 02-08-2016 1:30 PM
Hi Folks,
I've noticed that my Fibre Broadband speed seems to have dropped by a considerable margin, even though (to my knowledge) nothing has changed on my account etc. Plusnet reports that 73-80mb should be available in my area going by postcode + phone number
I've been looking in the stats page on my Draytek 2850n VDSL router after noticied slower speeds and my Data Rate has fallen to 57mb. Where's the other 20 megs gone, I'm nearly losing a whole other fiber connection there!
Any one got ideas? Is there any reason the upstream stops at 20, rather than the 25 it can supposedly attain?
Below is the VDSL Status table from the 2850n
Re: Fibre Broadband speed has dropped big time?
02-08-2016 1:35 PM
Our tests aren't showing any obvious cause for this.
I'd recommend raising a fault at https://faults.plus.net
02-08-2016 1:36 PM - edited 02-08-2016 1:37 PM
I was just trying to get a WBC speedtest run from the BT site, it says it cant run one against my phone number?
I'll go through the faults page now, but it definitely feels like something isnt right here.
edit: Apparently my conenction is on a different phone number to what I think my home phone number is, how can i find out my phone number (supplied by PN) as i dont actually own a landline phone.
02-08-2016 1:40 PM
You can check your number here https://www.plus.net/plustalk/index.php?page=choose_account
02-08-2016 1:41 PM
ok got the number, however since i don't have a phone i cant answer the 'Is the dial tone clear' question on the fault checker.
