Fibre Broadband only had connection with you for 3 weeks and connection keeps cutting out HELP HELP
- Fibre Broadband only had connection with you for 3...
Re: Fibre Broadband only had connection with you for 3 weeks and connection keeps cutting out HELP H
09-12-2016 3:36 PM
Best Idea would be to Borrow a router from a friend to rule out your router
09-12-2016 4:12 PM
I don't have any friends.
Please send me a router in case this one is faulty.
09-12-2016 5:55 PM
After our discussion on Facebook tonight, we've got it booked for tomorrow afternoon. Bit of a fluke that the weekend slot was available, as they're very rare for faults and nonexistent for provision.
Let us know how you get on.
Matty
10-12-2016 8:32 AM
I think cancel the engineer for now and I will let you know if any problems arise over the weekend (hopefully it's fixed itself!)
10-12-2016 9:48 AM
Fantastic news, happy to hear the connection appears to be more stable.
Checking the fault with our suppliers, they detected the line was not right when tested (after Matty booked the engineer). They performed remote work on your line which appears to have resolved the fault.
The fault has been passed back to us so the appointment has been cancelled.
I'm not in the office now, but I'll check up on your connection on Monday. Fingers crossed it remains stable.
12-12-2016 8:07 AM
HOWEVER when playing online games I get a huge amount of lag and a high ping (140 ms which should be around 40ms). I am using a power line adapter and have done a speed test which came back with download 17mb upload 1.5mb.
This really shouldn't be happening with a fibre connection can you please offer some help on how to fix this - I am also getting a huge amount of lag when using the wireless on the PS3 so I don't think power line is the problem
12-12-2016 8:59 AM
I'm testing your broadband and it's not bringing up any issues now. Can you try connecting using a wired connection to the router, just to bypass your powerline adapters?
12-12-2016 9:31 AM
I can do so tonight when home from work
Can you think of anything else that may be causing it - do I need to change something in the router settings?
18-12-2016 12:23 PM
Still not working properly - I have this weekend connected an ethernet cable from the computer direct to the router instead of using the powerline adapter
My ping in a game is over 140ms - it should be more like 30-40!!!
I can't see any other way than to cancel the service with you and go with someone else unless you can help?
18-12-2016 12:39 PM - edited 18-12-2016 12:40 PM
Sorry to hear you're still having issues.
Looking at your connection, it looks pretty stable:
Probably the next step is to try a reboot of the router to refresh the PPP session. Testing the broadband the circuit is still under estimates:
Sync Status | In Sync |
Downstream Speed | 20.0 Mbps |
Upstream Speed | 1.6 Mbps |
I'll be happy to arrange that engineer to look into that, but it's possibly an unrelated to the latency.
26-12-2016 10:30 PM
When is this problem getting fixed or is this to be accepted as the norm for your internet service? If so I want out
27-12-2016 12:31 PM
Sorry to hear you're having issues with your broadband again.
Looking at your connection, there are multiple drops:
Broadband tests aren't identifying an issue,
Downstream Speed | 21.7 Mbps |
Upstream Speed | 1.2 Mbps |
Voice Line Test Result | Pass |
If you've tried the test socket check as outlined here: https://community.plus.net/t5/Library/Testing-From-The-Master-Socket/ba-p/1322242
I would then advise you to raise this to us as a fault at http://faults.plus.net
27-12-2016 12:46 PM
Why does the router go red?
It was flashing red
Last night kept going orange and cutting out
What can we do from here? Still a poor service and to have no internet over the holidays is very disappointing indeed
27-12-2016 12:51 PM
The router appears to be losing sync. It indicates a physical fault somewhere, either your internal wiring or a fault outside.
27-12-2016 12:56 PM
