Fibre Broadband only had connection with you for 3 weeks and connection keeps cutting out HELP HELP
chrispeach1
Newly installed fibre and had this service with you for the past 3 weeks.
It keeps randomly cutting out and will then start again about a minute later
The broadband light goes from blue to orange then back to blue
Why is this happening? I am paying a lot for this service and this isn't the standard I was expecting to receive
Please provide assistance as soon as possible thanks
MattyC
Champion
Fixes: 46
Re: Fibre Broadband only had connection with you for 3 weeks and connection keeps cutting out HELP H
With the nature of the errors that your getting on your line, it seems to suggest that there may be an issue with the equipment. I note that we've sent you a couple of routers in the past 4 months, do the same issues persist with each router installed?
Matty
chrispeach1
Hi Matty
Thank you for your prompt reply.
I have only ever been sent 1 router which is the one I am using now.
I did plan on moving house back in August but I never received a router.
I did have a router at my old address however I could not benefit from fibre.
Are you able to run a test on the line to check that there is no adverse issue?
Kind regards
Chris
chrispeach1
Hi can you or someone please get back to me have come home from
Work tonight trying to use internet which keeps cutting out every 5-10 minutes. Have tried unplugging everything from the router and reconnecting but the issue persists.....
Plusnet Staff
Plusnet Staff
Fixes: 117
I've tested your broadband and it's indicated a possible fault with the line.
Voice Line Test Result Voice fault suspected - contact Voice CP to progress copper issue
Testing your line I've detected a Battery Contact and I've raised this with Openreach. The estimated response time is by 05/12/16. I've also opened a ticket on your account so that our faults team can monitor the progress.
From when I joined the Plusnet Help Team in May 2017 my main Community account is @Gandalf.
 Plusnet Staff
chrispeach1
Hi so openreach rang on Saturday to say they had fixed the problem but unfortunately today the connection still keeps cutting out please help
Plusnet Staff
Plusnet Staff
Fixes: 117
Downstream Speed 20.5 Mbps
Upstream Speed 1.3 Mbps
Voice Line Test Result Pass
Looking at your connection the drop outs appear to have subsided, however from testing your broadband the router is in sync below the estimated speed.
I would advise to raise a fault to us at http://faults.plus.net
 Plusnet Staff
chrispeach1
Hi
I don't know how to feel about your response.
The issue isn't fixed as it keeps cutting out.
I am also paying you £33.99 per month for this service which isn't satisfactory.
You are also asking ME (the customer) to raise a fault - why cant you do it? I have already raised a fault.
You had no problem in debiting the money from my account so I assume you will get this fixed urgently.
Plusnet Staff
Plusnet Staff
Fixes: 117
As we cannot determine where the problem lies, I wouldn't be able to raise a fault on your behalf because the low sync speed and drop outs can be caused by internal wiring, which the broadband trouble shooter will aim to help you determine where the problem lies by trying the test socket (found by unscrewing the front cover of the master phone socket).
If you let us know once you have completed the troubleshooter I'll progress the fault for you.
 Plusnet Staff
chrispeach1
Done can you please check to see what the problem is trying to watch Netflix and it keeps cutting out!
Plusnet Staff
Plusnet Staff
Fixes: 117
I'll take a look into your fault ticket tomorrow once I am back in the office.
Many apologies for the inconvenience caused.
 Plusnet Staff
Fixes: 33
Just a thought, how are you connecting, Wifi or wired?
Plusnet Staff
Plusnet Staff
Fixes: 117
That's a good point @Mustrum because whilst the sync speed is low there aren't many drop outs between the exchange and the router.
 Plusnet Staff
chrispeach1
Both
chrispeach1
Any news?
On driving into work this morning your company advert was played on the radio, something about "plusnet... We will do you proud". Not sure about that at the moment!!!!
Can you not just send a new router out to eliminate whether the router is faultyHuh
