Fibre Broadband disconnections several times a day.
Celt
I'm having constant disconnections from my fibre broadband, gradually getting worse over last month. The router light changes to orange before reconnecting.
Getting annoying could you please look into this
Celt
Re: Fibre Broadband disconnections several times a day.
Guess there is no longer support on this forum. Tried phoning but don't have hrs to wait being on hold.
Starting to regret joining plus net
BrightonRock
Fixes: 6
Welcome to the Forum @Celt. As you observed, Plusnet staff haven't been in the Forum today; they tend to be thin on the ground most weekends.
I suggest that you run through the checks at https://www.plus.net/help/broadband/connection-troubleshooting/ and report a fault at https://www.plus.net/apps/kbdfaults
That gets the problem onto Plusnet's to do list and queued for attention.
Fixes: 219
Apologies for the delayed response.
I can see that the line was dropping but now appears to be stable.
If the drops start again I'd recommend raising a fault here
 Matthew Wheeler
