Fibre Broadband Speed
FIXED- Subscribe to RSS Feed
- Re: Fibre Broadband Speed
- « Previous
- Next »
29-06-2018 3:51 PM
OK
Two engineers came today.
One reported a fault on my line but there were no spare.
A second came on the same day and added a spare line.
Phone now works.
The Internet via wired connection holds a speed of 40 MBps
The second engineer confirmed speed will go up and down over the next few hours as the line "learns" but I can say the problem is solved! Question #177192084 updated!
Let me know what you suggest as refund for the downtime considering the issue was raised 3 weeks ago.
Thank you all
29-06-2018 4:08 PM
Hi there.
I have raised a ticket on your account regarding the refund. You can view this at https://www.plus.net/wizard/?p=view_question&id=177192084
30-06-2018 8:21 AM
Oh dear. I do hope this is not a sign of things to come. So I've been back with Plusnet for 2 weeks and overnight last night, my internet speed has inexplicably dropped by 5mbps and there has obviously been 'downtime' on my router because the BT HH6 is showing this to be the case. I fear someone, somewhere at the exchange end has been mucking about with my fibre. As it is, I'm still not convinced that I'm getting anywhere near the speed I should be getting. I wouldn't mind, but everything has been pretty much ok for the last couple of weeks and now the reduction in speed. Plusnet, please tell me what is going on? Oh, and I don't want to read any excuses about the fact that I'm getting above the minimum guaranteed speed, thank you.
30-06-2018 5:33 PM - edited 30-06-2018 5:35 PM
Hi @Kimberlin,
I'm sorry to hear that your speed has dropped over night. I've tested your line however it's not picking up the cause of this.
GEA Test Detail | |||
Circuit ID | NA | Service ID | BBEU29546217 |
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0000 | ||||
Description | GEA service test completed and no fault found . | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 49.2 Mbps | ||||
Upstream Speed | 14.2 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Not Detected | ||||
Radio Frequency Ingress | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Cross Talk | Not Detected | ||||
Estimated Line Length In Metres | 573.1 | ||||
Upstream Rate Assessment | Reasonable | ||||
Downstream Rate Assessment | Reasonable | ||||
Interference Pattern | Not Detected | ||||
Service Impact | No Impact Observed | ||||
Home Wiring Problem | Not Detected | ||||
Technology | VDSL | ||||
Profile Name | 0.128M-80M Downstream, Interleaving Low - 0.128M-20M Upstream, Error Protection Off | ||||
Time Stamp | 2018-06-17T17:45:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 47.8 Mbps | 53.7 Mbps | 52.9 Mbps |
Up Stream Line Rate | 14.1 Mbps | 17.3 Mbps | 16.8 Mbps |
Up Time | 802.0 Sec | 900.0 Sec | 899.8 Sec |
Retrains | 0.0 | 1.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2018-06-30T17:05:00.155+01:00 | 2018-06-30T17:20:00.155+01:00 |
Ingress Code Violation | 0 | 4 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 7 | 4 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
Whilst I appreciate what you're saying regarding the drop in speed and the fact that it is towards the bottom end of the line's estimates, it's above the minimum guaranteed speed and that means that we are very limited in terms of what we can do with this for you as our suppliers would not investigate this as a fault. Please keep an eye on your connection over the next few weeks and let us know if your speed drops below the minimum guaranteed speed of 42.2mbps on a wired connection as we would then be able to investigate this as a fault.
- « Previous
- Next »
