Fibre Broadband Speed and Phone Line Issues
chris4
For over two weeks we have noticed a reduced broadband speed, we were getting around 20 Mbps (which was inline with the original estimation when we changed over to Fibre) and now we are lucky to get 5 Mbps (we were getting better speeds before paying the extra to have Fibre.)
The BTW Performance Test, returned;
Download @ 3.97 Mbps
Upload @ 0.07 Mbps
Ping Latency @ 0.00 ms
The other Member centre test did not provide an estimate but gave a current line speed of 7.7 Mbps.
This was all with the laptop plugged directly into the router and I have tried re-setting the router multiple times.
On checking for other issues our phone does not have a dial tone and we cannot call out, you can call the number and it rings on the phone calling but not on the home phone. This seems odd as it appears we have no line but are still getting some Broadband?
Has anyone had similar issues? Can anyone help?
Fixes: 236
Re: Fibre Broadband Speed and Phone Line Issues
Sorry to hear that.
Our tests are finding a external fault so we've got that raised for you.
 Matthew Wheeler
chris4
Thanks for the update Matthew, I will keep you posted on progress.
