Fibre Broadband Speed Below Estimate
- Re: Fibre Broadband Speed Below Estimate
27-07-2016 4:45 PM
I upgraded to fibre on 5th July and was achieving a connection speed of 23Mb. This was within the estimated 18-25Mb, so I was happy with that.
Since then the speed has dropped to 15Mb. I raised a Question #129885678 and the CS rep said that they would arrange a reset. This was on 20th July, but the speed has remained at 15Mb.
I have tried contacting CS again, but no response.
Can someone at Plusnet please look into this. Thank you.
27-07-2016 4:57 PM
I'm just testing your line now, however on initial glance I'd advise reporting this to us as a fault at https://faults.plus.net - the advisor you spoke to previously did not do the right thing, so I've passed feedback on about that and offer my apologies.
There's a little instability on your line, it drops out every now and then.
Description | GEA service test completed and no fault found but unable to check for customer equipment connected to modem. |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 16.3 Mbps |
Upstream Speed | 2.0 Mbps |
27-07-2016 5:22 PM
Thanks Chris. I did try a few soft disconnects to see if it improved, but it obviously didn't. As requested, I have raised a fault.
27-07-2016 5:30 PM
Thanks for that. I've pushed the fault through to our suppliers on this and updated the ticket.
02-08-2016 5:18 PM
Hi PN. I haven't heard anything from OR or yourselves yet on this. Speed still sub 15Mb.
03-08-2016 11:01 AM
I've just checked the fault and it's going to need an engineer, can you respond to the ticket on your account with the information requested.
03-08-2016 5:29 PM
I have responded and given you times and days. Thanks
