Fibre BB speed falling
Following significant speed issues earlier in the year resulting in an engineer visit which ultimately resulted in speed been restored to 34-35Mbps, this speed has remained rock solid and has been checked on a regular basis. However over the last ten days the speed has gradually started to slow and is now at 31Mbps. Nothing has changed in my set up or the way I measure the speed. What is the most likely cause of this slowing, is it likely Plusnet are gradually slowing down my service ?
1 REPLY 1
Re: Fibre BB speed falling
Exactly the same issue here; had even less than 10mbps this evening. Unbelievable. Never really able to get up to anything more than 30mbps. Changed the package ordered the router which never turned up either. Very frustrating.
