Fibre Activated today Download speed same as ADSL 4MB
- Re: Fibre Activated today Download speed same as A...
09-03-2016 1:13 PM
Hi my FTTC was activated today, upload speed it fine, but the download speed it around 4MBs. This cannot be right. This is the same speed I had with ADSL, looking at other posts it seems this may be a setting that needs changing at your end. Can you help.
username simonrennison
Message 1 of 5
(1,049 Views)
4 REPLIES 4
Re: Fibre Activated today Download speed same as ADSL 4MB
09-03-2016 1:15 PM
Can you try again after a disconnect/reconnect please.
Message 2 of 5
(663 Views)
09-03-2016 1:23 PM
Thank you, your fix and a restart has done the trick.
Si
Si
Message 3 of 5
(663 Views)
09-03-2016 8:37 PM
It's rather annoying as every new customer sign up new fibre or upgrade fibre from ADSL or ADSL2+ as Plusnet doesn't seem to be bother to set the current line speed at 38Mb for Fibre up to 38Meg or 78Mb for Fibre up to 76Meg.
I think they should set the fibre current line speed once the fibre was completed by Openreach. My mate been waiting for the correct profile on PN side after 4 weeks when his fibre went live but stuck at 21Mb before changed to 78Mb after 4 weeks!
Message 4 of 5
(663 Views)
10-03-2016 8:43 AM
In the majority of cases this does happen automatically.
Has he contacted us?
Quote My mate been waiting for the correct profile on PN side after 4 weeks when his fibre went live but stuck at 21Mb before changed to 78Mb after 4 weeks!
Message 5 of 5
(663 Views)
