Fiber disconnections at least once a day and net lagging.
- Fiber disconnections at least once a day and net l...
28-10-2015 1:46 PM
Is there any chance i can get one of them radius graph things to see whats going on as im am used to having my connection stay up for weeks at a time.
I've also noticed my speed has droped down to 32mbps where as before the recent issues i was connected at full speed and had no issues at all for ages.
My connection also feels like its lagging a lot on many websites, pages fail to load or time out randomly or just take ages to load and i also think my modem might be fualty as the reset button never seems to work if i want to use it.
Re: Fiber disconnections at least once a day and net lagging.
28-10-2015 2:35 PM
Its really noticeable while playing games or talking over VoIP (teamspeak for example).
For me the connection isnt dropping just lagging really badly in spikes.
I have checked the usual things and there doesnt seem to be anything my end.
I replaced my router not to long ago as it was suspected my old one was at fault (which did fix a previous issue).
The speed seems ok but just very often im getting spikes of huge latency and it seems like throttling rather than connection issues as i dont think packets are dropping.
Not sure what details are required but i noticed this post and there is another as well so it sounds like it might not be just me?
28-10-2015 3:55 PM
I also know the connection drops due to the new ip showing in my router and due to being kicked out of world of warcraft or what ever online game i am playing at the time.
From what i can tell the connection usualy drops out at night but the time can range from early evening to early hours of the morning.
Usualy i would not care but its happening way to often for my likeing and its starting to annoy me especialy when i get kicked from world of warcraft in the middle of a raid or boss fight.
when i can finaly log back in, i'm dead and have to waste loads of gold on fixing my equipments grrrrrrrrrr.
If possible could a plusnet staff memeber tell me what type of cab im connected to aswell please.
@devonshiredan no its not just you seeing simler things and to be honest this all seems to stem back to when plusnet had issues about a month ago or when ever it was.
28-10-2015 4:54 PM
I too have the exact same faults as reported here. see my post fibre lagging.
Funny enough my problem started about 1 month ago too.
I too am technically minded with 30 years experience.
My connection also feels like its lagging a lot on many websites, pages fail to load or time out randomly. It was blissful to see my router connected 40 days at a time. Now I am lucky to go 72 hours without a disconnect. The lag is killing all enjoyment. I have changed from the plusnet router to 3 Bt hubs and back again with no improvement at all.
Hope you get the problem sorted.
Rob
28-10-2015 6:20 PM
Thanks for your reply
I've tried a few things such as using open DNS or google DNS and none of that helped.
The odd thing is i don't seem to be having issues with latency that have noticed its just the net feels really slugish and the droped connections.
28-10-2015 7:53 PM
I've been on the Thompson. I recently moved to the Sagemcom and started getting disconnections every day. Moved back to the Thompson and it all stopped. Lots of people having issues with the Sagemcom routers from what I can see here on the forums.
29-10-2015 11:26 AM
30-10-2015 4:44 PM
Either sort it out or i'm off
30-10-2015 6:19 PM
Quote from: spudbynight
Yes the Sagemcom seems to be extremely unreliable.
31-10-2015 12:02 PM
It's not looking good
http://www.thinkbroadband.com/speedtest/results.html?id=1446293708254699955
02-11-2015 9:52 AM
24-11-2015 4:09 PM
What happens is and as can be seen from my pics, my speed seems to drop to half and then stays there for ages and at the same time my BT profile plays silly games, i will run a test and it will say my download is 15mbps but my profile is 32.3mbps then the profile itself will drop to 15mbps then about 2 hours later it seems to go back up but my speed stays at 15mbps.
Does anyone have any idea what might cause this? it's happened 2 or 3 times since i made the original post.
BTW all my tests are done wired as i hate wireless so its not a wireless issue.
25-11-2015 1:24 PM
25-11-2015 1:39 PM
25-11-2015 2:12 PM
http://faults.plus.net
It will still let you raise if you state that the issue is ongoing. Thank you.
