Fiber Speed Dropped from 30 to 10 Mbps
tudou
I've noticed that my connection has been particularly slow recently compared to what it has been in the past. As the title indicates, when I first switched to fibre I was getting speeds of up to 32 Mbps. Recent tests have been around 9, struggling to get to 10 Mbps.
BT's website shows that I should be getting:
Fibre broadband
25Mb-33Mb Estimated download speed* range
20Mb Minimum speed guarantee*
At dslchecker.bt.com I can see the line has a downstream rate of 32.8 Mbps (clean) and 25 (impacted).
Could someone please help me with getting this issue sorted and speeds back to the service I should be getting.
Thanks.
Moderator's note by Mike (Mav): Post released from Spam Filter
Fixes: 461
Re: Fiber Speed Dropped from 30 to 10 Mbps
Sorry about the lack of response.
My tests aren't detecting any issues.
Sync Status In Sync
Downstream Speed 26.2 Mbps
Upstream Speed 2.0 Mbps
Voice Line Test Result Pass
Are you using a wireless or wired connection?
Anoush
tudou
It's a wireless connection. All my previous speed tests that I've run have been on wireless and were able to achieve 26-32 Mbps so that shouldn't be the issue.
Just re-ran speedtest tonight and managed to reach 24 Mbps. Seems to have resolved itself - I assume Plusnet doesn't throttle bandwidth at certain times of the day?
Fixes: 163
Nope, we wouldn't be allowed to advertise the service as Unlimited if we throttled bandwidth
 Chris Parr
 Plusnet Staff
