Fiber Installed Friday morning issue
- Re: Fiber Installed Friday morning issue
08-12-2014 1:37 PM
So the Openreach engineer actually arrived this Friday and installed my Fiber all went well and I was up and running in no time, First go at the install was a no goer engineer even said he called but that did not happen as I was sat waiting for him from 07:00.
Only issue I do have is I still have the 20 meg down I had before but with 20 meg up instead of the 1 I had before, As the exchange is quite litterally a stones throw from m house and the box not much further away I should be expecting pretty much 70 - 80 meg down any chance some one at Plus net could take a peek at this please
Message 1 of 4
(899 Views)
3 REPLIES 3
08-12-2014 2:33 PM
Hi there.
Your connection hasn't dropped since the profile updated on our end so your speeds will be stuck at their old ways.
If you try rebooting your router or logging into it and doing a manual disconnect/reconnect the issue should be resolved.
If you have any further issues let us know.
Message 2 of 4
(550 Views)
08-12-2014 3:22 PM
Yep that did it thanks, Funny really I was told to leave all the equipment on and not disturb it for at least a week. As a techie I installed a Vigor 2830n as I'm used to working on these.
Message 3 of 4
(550 Views)
08-12-2014 3:26 PM
Fantastic.
Glad to hear that's done the trick. With regards to not touching the equipment that applies more to the Openreach modem then the router but fingers crossed you don't have to touch it again.
Message 4 of 4
(550 Views)
