Fiber Connection
Alex2x
Fiber Connection
Hi all, im due to get connected to Fiber tomorrow, but I work away from home and am away for 2 days, i was wondering will my BB connection still work with the old modem pluged in after fiber upgrade. Just dont want my girlfriend to be without a connection until i get back. I have the new fiber router but was told not to connect it until notified too.
Plusnet Staff
Plusnet Staff
Fixes: 117
Re: Fiber Connection
Hello @Alex2x
The new router will work with your existing broadband connection.
If you set it up tonight and start using it, the switchover tomorrow should be seamless.
I hope this helps but if you have any further queries please feel free to just ask.
From when I joined the Plusnet Help Team in May 2017 my main Community account is @Gandalf.
 Plusnet Staff
Alex2x
Thank you
Plusnet Staff
Plusnet Staff
Fixes: 117
No problems.
 Plusnet Staff
Alex2x
HI again as we discussed last night I switched to the new router. Everything worked got up for work this morning at 05:30 to an email saying the switch to Fiber was now complete. I'm still away from home and just recived a call from my girlfriend saying there is no Internet and an orange light on the front of the router and suggestions
Plusnet Staff
Plusnet Staff
Fixes: 117
Hmm, any lights flashing on the router?
I'm on annual leave for the rest of the week, however if you private message me with your landline phone number (if you know it) I'll be happy to run a few diagnostics.
Thanks for your PM @Alex2x
Initial diagnostics aren't showing any reported outages, but the full test has failed to run via the systems we use. It has however indicated a possible issue with the line itself.
I'd advise to run a line test here. At the moment, I don't believe the result of this line test you can run yourself will be very informative, so I'd advise to then check here for any open tickets that may indicate a fault has been automatically raised.
Failing the above, try a factory reset of the router. Wait 5-10 mins, if that doesn't help then go to the router settings at http://192.168.1.254, navigate to Advanced Settings, select the Broadband option from the pink banner once logged in, make sure the username it's using is YourUsername@plusdsl.net and the password is the Account Password then press Connect.
The final step I'd suggest to raising a fault to us at http://faults.plus.net if you need to.
 Plusnet Staff
Alex2x
Thanks for trying line check doesnt work cant really do anything else atm because im not at home will try to log into the router tomorrow Cheerss
Plusnet Staff
Plusnet Staff
Fixes: 117
No problems, feel free to let me know if you need any further help.
 Plusnet Staff
