Faulty Router Hub Zero 2704n
- Re: Faulty Router Hub Zero 2704n
22-09-2016 6:25 PM
My router keeps dropping the WiFi. The light remains on but there is no Wireless signal broadcast.
I have tried disabling the Wi-Fi in the router, and re-enabling and turn off/on the phone/firetv box and back on but the only fix is for me to power-cycle the router, which is not ideal.
Please can I request a replacement router is sent out.
Firmware version: |
7.273.1_F2704N_Plusnet
22-09-2016 7:19 PM
Plusnet only guarantee the router/modems for 12 months. So I'm going to bet you've had your's for longer. If I wrong then sorry.
If I'm right then the options are
- If you have recontracted with Plusnet within the last 3 months then it will only cost you £6.99 P&P for a new device from Plusnet
- If you recontract now, then again only £6.99 P&P as you have just taken out a new 18/24 months contract
- Pay Plusnet £100 , yes ONE HUNDRED POUNDS
- Buy your own device for much less
23-09-2016 9:10 AM
It might be worth completing a Factory Reset as well, just to see if that resolves the issue before looking at an alternative router.
23-09-2016 9:21 AM
Surely if a Plusnet supplied router fails PN would replace it FOC in order for the customer to continue to have PN as their provider.
When I was with Be my router failed it was old as well they sent me a replacement FOC.
In fact it was a Sunday afternoon and their support confirmed it was faulty and much to my surprise at breakfast time next day it arrived.
23-09-2016 9:24 AM
If it's proven to be faulty and is within the 12 month warranty period, the router would be replaced.
23-09-2016 9:33 AM
That's good but if over 12 month no you say well if a provider did that to me I would walk.
You must bear in mind a breaking down router user is most likely out of contract, and a new provider would be supplying a brand new router.
