Faulty BT Openreach Modem
mickb82
Over the last week I have found that my internet connection is not as fast as usual. Today I have been getting around 18mb download speed, I usually get around 43mb.
I have tried replacing all the cables and I have also tested the speeds with my PC connected directly to the openreach modem, this made no difference.
When I was testing the connection directly from the openreach modem I found that if I turned the power off to the openreach modem for around 10 minutes when I power it back up the speeds were back to normal for a few minutes then they would decrease again.
I have dismantled the openreach modem to check the internal components and I found that 2 of the capacitors on the circuit board have started to leak.
Can plusnet send me a new openreach modem or do I need to get in touch with openreach about getting a replacement?
I have attached some pictures showing the 2 leaking capacitors.
Thanks,
Plusnet Staff
Plusnet Staff
Fixes: 117
Re: Faulty BT Openreach Modem
Hello there.
That doesn't sound good, though we wouldn't be able to replace the Openreach modem I'm afraid. Since we introduced the self install process and provided customers with our Hub One, which is a combined modem router, we aren't able to re order the OR modems.
I'm not sure that you would be able to contact Openreach for a replacement, however their modems are available on the web from places like Amazon. Second hand, I imagine and at cost, though.
From when I joined the Plusnet Help Team in May 2017 my main Community account is @Gandalf.
 Plusnet Staff
mickb82
If the openreach modems are no longer available how do I go about replacing it with the new type router you mentioned. Can you arrange for one of these to be sent out or do I need to phone customer services to arrange for a replacement to be sent out.
Thanks.
Plusnet Staff
Plusnet Staff
Fixes: 117
Could you PM me your username please and I'll see what we can offer you?
 Plusnet Staff
SpendLessTime
Aspiring Hero
Fixes: 80
@mickb82
Plusnet will charge £100 for a new combined modem/router unless you have just recontracted within the last 3 months then they will just charge for P&P at £6.99. Or you want to contract again. (note the guarantee is only for 12 months on the Hub One but the contract maybe for 18 or 24 months and you could find yourself in the same situation in 14 months time)
Given that the Plusnet Hub One is a rebadged BT Home Hub 5 Type A, you would be better off getting one of those on ebay for about £25 delivered.
Or buy your own new device from elsewhere, a good place to look for which device is http://forum.kitz.co.uk/index.php/topic,14436.0.html as Kitz is a Plusnet customers and very knowledge about communications. That link shows a list of devices and discusses the features of them. It is constantly updated.
mickb82
Thanks for the information
I should hopefully be offered a replacement as I signed up to a new 18 month contract 2 months ago.
dannyboy75
OP - if you prefer to retain your existing router, there are plenty of OpenReach modems on eBay, selling for a few pounds.
Some are Huawei and others are ECI, but to all intents and purposes they're the same. I have both models at home and they work equally well.
nightstalk3r
If you do go down the route of buying another Openreach modem avoid the ECI ones at all cost as they don't support G.INP.
Plusnet Staff
Plusnet Staff
Fixes: 117
Thanks for your PM.
As you're within the first 3 months of your contract if you speak with our customer options team on 0800 013 2632 (Selecting the option for I'm thinking of leaving), we'll be able to offer you the Hub One router free of charge, however they may ask for the postage and packaging of £6.99. That department are open until 8 this evening and currently have no call queue (if you can call now, that is).
 Plusnet Staff
mickb82
Thanks for your help,
I have contacted the customer options team and they are sending me a new Hub One router in the next 3 to 5 working days.
Thanks.
Moderator's note by Mike (Mav): Full quote of preceding post removed as per Forum rules
