Fault reported but so quiet from Plusnet Ticket ID #116663426
- Fault reported but so quiet from Plusnet Ticket ID...
23-12-2015 9:26 PM
I'm paying for a 80/20 service but currently, the latest BT test show below 40mb download with a dreadful 3.15mb for the upload side.
So what does it take to get things moving? I do appreciate that brevity can be a blessing when it comes to the use of the English language but to see just
'Kind regards,
Travis Cartwright' as an answer, helps me not one bit.
While I understand my 'Plusnet line speed setting' seems to be down to 66mb (it was fine at well over 70mb as evident by the first tests done in ticket #115091512) it would be nice if someone could let me know what is being done. Currently I am completely in the dark.
Re: Fault reported but so quiet from Plusnet Ticket ID #116663426
28-12-2015 11:14 AM
28-12-2015 11:22 AM
Either way
What does this give http://www.thinkbroadband.com/speedtest.html and what is the current line speed - see my sig for a link
28-12-2015 11:26 AM
sorry this hasn't been picked up yet, I've spoken to one of my colleagues in our tech team and he's going to look over things, it may need our faults team to look into further but I'll get it passed to someone if needs be.
28-12-2015 11:34 AM
I've passed your account to someone in our faults team who should be getting in touch to get this looked into for you
28-12-2015 11:49 AM
Quote from: Oldjim Was that test via the quick link or via the normal test then further diagnostics
Either way
I've done the test both ways. Results are about the same. Current Plusnet line speed is 65.2 Mb which is much less than what it was originally and another meg down on last week.
My last thinkbroadband http://www.thinkbroadband.com/speedtest/results.html?id=145122797325503784374. 56.42 Mbps Problem is I tend to cancel the test if it's well down 😞 Nothing worse than confirming what one feels already. It's one reason why I did another BT test this morning. I tried uploading some photos and it was taking ages.
Darkfire Thanks for that. I did chat to someone before Christmas and they said they'd redo the IP profile but if anything things have gone the other ways since!
28-12-2015 12:36 PM
28-12-2015 3:14 PM
I've just done another BTW test which is much healthier (below - not top notch but certainly better) as is the TBB tests run just now http://www.thinkbroadband.com/speedtest/results.html?id=145131252323786557245 that was wireless, this 2nd one was run wired http://www.thinkbroadband.com/speedtest/results.html?id=145131311322481647487
What I don't understand is why, when it gets / seems to throttled, it tends to go to a figure around 40 megs and 3 megs upload.
28-12-2015 3:17 PM
28-12-2015 3:38 PM
I've got to go out now but will disconnect the router later (does it matter for how long?) and I take it you mean to leave the modem connected? I'll run a test later too.
28-12-2015 3:40 PM
29-12-2015 9:39 AM
BTW test (below) done this morning (wired direct on the modem). Although I include the TBB test done last night (again wired ... ) ....bit of a mix bag. Is this congestion?
08-01-2016 7:26 PM
14-01-2016 6:03 PM
Beginning to feel I've been miss-sold a fibre connection.
15-01-2016 9:12 PM
Quote from: idonno Well this is pretty cr*p. Maybe I should have stayed with BT.
BT bought Plusnet a while ago, so in reality you're still with BT.
