Fault on my line / accuracy of dslchecker
- Fault on my line / accuracy of dslchecker
07-11-2016 3:41 PM
I've been with Plusnet on Unlimited Fibre Extra since March this year and have only ever had a speed of around 49-51mb and 17-18mb up. Output for my phone number on dslchecker is below:
Does this indicate some kind of fault on my line?
Re: Fault on my line / accuracy of dslchecker
07-11-2016 3:55 PM
Test Outcome | Pass |
Test Outcome Code | GTC_FTTC_SERVICE_0001 |
Description | GEA service test completed and no fault found but unable to check for customer equipment connected to modem. |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 52.1 Mbps |
Upstream Speed | 18.2 Mbps |
I've attached your sync speeds from a line test above, as you can see it's significantly lower than the bottom end of your estimate, so I'd advise getting this reported to us as a fault at https://faults.plus.net
Let us know when you've reported it and we'll take a look at the fault ticket.
07-11-2016 4:18 PM
Thanks, I have now reported this as a fault. I will update the thread when I hear back.
19-11-2016 6:34 PM - edited 19-11-2016 6:36 PM
Just thought I'd post to update.
Plusnet quite promptly arranged for a BT engineer to take a look as the "Minimum Guaranteed Access Line Rate" for my line is 57mb and I was only getting about 51mb.
The engineer was very pleasant and thorough and found there was a considerable amount of noise on my particular line coming into the block of flats where I live. He was able to swap my flat onto an unused line coming into the building for one with much less noise.
I am now syncing at 77.69 Mbps and achieving about 73MB in speed tests.
Thanks Plusnet / BT.
19-11-2016 8:44 PM
Thanks for reporting back, I'm glad to hear you're back up to speed
