Fault checking
Fixes: 6
Fault checking
It appears BTWholesale have up-dated the availability checker to include a check for a "Bridge Tap" which can impact a line. See
http://www.ispreview.co.uk/index.php/2017/05/bt-wholesales-uk-broadband-checker-adds-status-bridge-t...
1 REPLY
Fixes: 17
Re: Fault checking
A Bridge Tap is usually an internal wiring issue. Any extension wiring without a centralised filtered faceplate (unless it's where you plug in the modem) is a bridge tap. It wouldn't usually be something you'd get Openreach out to fix.
