Fault Ticket Update
Olifran
Fault Ticket Update
Hi
Can a member of PN update me in my ticket
127476313
Chris
Fixes: 163
Re: Fault Ticket Update
I've checked the fault and there hasn't been a decent update yet, the fault has come back from BT saying the line tested ok.
Can you run a BT speedtest, ensuring the 'further diagnostics' test is run after the first one completes, this will record the performance of the line for us.
 Chris Parr
 Plusnet Staff
Olifran
I have ran the speed test:
Home Image not loadedTesting Image not loadedResult Image not loaded
FAQ
Results Image not loaded
1. Best Effort Test: -provides background information.
  Download Speed
  6.38 Mbps
0 Mbps 6.56 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 6.38 Mbps
 For your connection, the acceptable range of speedsis 4.59 Mbps-6.56 Mbps .
 Additional Information:
 IP Profile for your line is - 6.56 Mbps
  Upload Speed
  6.45 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 6.45Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
Please visit the FAQ if you are unable to understand the test results.
Olifran
Chris
All good now. Re booted everything and did a wired speed test on BT. Results are now up as they should be.
Thanks for your help.
Feel free to delete/close this thread.
Fixes: 163
Good to hear, if you get any issues just update the fault, it'll remain open for 14 days to allow this.
 Chris Parr
 Plusnet Staff
