Fault Ticket Update
- Re: Fault Ticket Update
Fault Ticket Update
15-06-2016 12:58 PM
Hi
Can a member of PN update me in my ticket
127476313
Chris
15-06-2016 1:41 PM
I've checked the fault and there hasn't been a decent update yet, the fault has come back from BT saying the line tested ok.
Can you run a BT speedtest, ensuring the 'further diagnostics' test is run after the first one completes, this will record the performance of the line for us.
15-06-2016 8:08 PM
I have ran the speed test:
16-06-2016 8:26 PM - edited 16-06-2016 8:27 PM
All good now. Re booted everything and did a wired speed test on BT. Results are now up as they should be.
Thanks for your help.
Feel free to delete/close this thread.
17-06-2016 10:31 AM
Good to hear, if you get any issues just update the fault, it'll remain open for 14 days to allow this.
