Faster WiFi - New Router?
- Faster WiFi - New Router?
11-04-2017 5:17 PM - edited 11-04-2017 5:19 PM
I am on Unlimited FIbre Extra. My router is ASUS RT-N66U. My Broadband Speed shows 61.62 Mbps download and 18.70 Mbps Upload. Within my WiFi network files get transferred around at up to 10 MB/s (according to Windows 10). I keep my media files etc. on WDMYCLOUD drive. I do HD video editing on my PC, drawing the files from the WDMYCLOUD via WiFi . It is certainly works but video projects can take a while to boot up. I have installed Cat 6 network cables throughout e.g. from the router to the WDMYCloud and the WiFi is now faster. I prefer to stay with WiFi rather than all network cables but I wonder if a newer router would speed the WiFi further? Recommendations would be appreciated. Thanks
Re: Faster WiFi - New Router?
11-04-2017 6:27 PM
12-04-2017 7:50 AM - edited 12-04-2017 7:50 AM
Thanks for reply. Wireless adaptor is Killer Wireless - n/a/ac 1535
One thing, I quoted the speeds in the way they are displayed. The internet download speed was in Mbps (Megabits per second) and the network in MBps (Megabytes per second). So based on Mbps my 10 MBs network WiFi speed converts to 80 Mbps (I think that's right!).
12-04-2017 10:32 AM
12-04-2017 10:55 AM
What speed is the network card in the WDMYCLOUD running at?
Have you checked the speed you get when using a wired connection on the PC?
12-04-2017 4:00 PM
Thanks reply. Can't find speed of WD MYCLOUD network card at the moment. Wired connection via router and Ethernet cable shows copying files around to the WD MYCLOUD at just over 100 MBps. When connected via Ethernet status shows 1.0 Gbps.
WiFi status speed shows 144 Mbps. WiFi speed doesn't increase even PC is line of site to router.
12-04-2017 4:14 PM
There's your bottleneck.
You'll need to experiment with the settings on the router and WiFi adapter to bump that up, unfortunately I haven't used either before.
12-04-2017 5:34 PM
Looks like a configuration issue on the PC - perhaps it's not using the 5GHz?
12-04-2017 8:03 PM
Again, thanks for comment. Regret have set up and running 5 GHz, so not that. I wonder if something with the WiFi signal? Maybe antennas not transmitting signal correctly?
13-04-2017 1:12 PM
Now don't think it is the wifi signal. Even removing antennas merely causes weaker signal, but no change in data transfer rate.
17-04-2017 7:32 PM
Thanks for useful comments. I have managed to increase router WiFi speed to 300 Mbps by setting so it chooses bandwith 20/40 on 5 GHz. Files now transfer in my network about 15 MBps, much better than when I started.
I believe that my router max speed is 450 MBps. It is ASUS RT-N66U, a relatively old model. Would I be able to achieve significantly speed increase with a newer, better performance router? If so, which?
17-04-2017 8:07 PM
Probably any router with ac wireless would do better.
450Mbps on 11n requires 3 spatial streams, but the Killer™ Wireless-AC 1535 only supports 2 spatial streams, limiting it to 300Mbps with 11n.
20-04-2017 7:50 PM
Finally, I now have a PlusNet Hub One router. My Killer Wireless 1535 Network Adaptor now shows 866.7 Mbps WiFi
Copying files around the my network is about 40 MBps
With network cable Killer Wireless 1535 runs 1.0 Gbps and files copied about 45 MBps.
I am reasonably happy with this, unless someone tells me how I could achieve significantly higher speeds without too much cost and effort.
Thanks for the useful posts from contributors to this forum.
