Fast upload, slow download
SoupDragon
Woke up this morning to find our broadband is slow.
BTW Performance checker states:
Download Speed: 2.07Mbps
Upload Speed: 15.75Mbps
Ping Latency 245.75ms
Help! Smiley
47 REPLIES 47
veggiewoppa
Re: Fast upload, slow download
Sadly I can't help but I can confirm you're not the only one. I'm in the NP19 area of south Wales if that helps tie things together at all
adam1966
Same here in London E3.
rongtw
Fixes: 12
mm something odd here ?  @Gandalf can you check
rongtw
Fixes: 12
you can check BT service here see if your area has a fault https://btbusiness.custhelp.com/app/service_status/
or here https://status.zen.co.uk/broadband/
Shrui
rongtw
Fixes: 12
you are better testing here Thumbs_Up http://speedtest.btwholesale.com/
and take the further diagnostic test , it will save the test to your profile and PN can check
Shrui
Sorry for the repeat posts, I didn't actually click post on those!
Testing at the wholesale test I get:
Glasgow G51
Download: 1.16Mbps
Upload: 1.78Mpbs
Ping is up and down, sometimes 26 or 48 ms, sometimes spikes to 250ms
bigwest
Nozbit
Same as everyone else. Chronic download speeds of less than 2mb this morning on a hardwired connection. Upload is fine.
Bishopp376
Same here in Wiltshire. 30 minute wait to call Plusnet!
Lucky if I can get 1mbps download but upload not affected.
malfunkshun
same issue, in addition to issues with website load time I have had for a few days. Cant run the BTW further tests for some reason. Started some time around 130am I think.
Oh, I am in Pembrokeshire btw.
TheCommsGuy
Same here in sunny Suffolk (1Mbps Down, 16Mbps Up), seems to have happened at just past midnight which usually means it's down to a centralised BT change. All logged with PlusNet & BT... & wait
marcusk
Same, Banbury. Poor service yet again.
1. Best Effort Test:
Download Speed : 1.81 Mbps
2. Upstream Test:
Upload Speed : 3.55 Mbps
DanCarreras
Same here in Oxfordshire! (Banbury)
Spent an hour on the phone to support and they have no idea what's happening. Escalated to faults, and think it's a local issue. Annoyingly, nothing on site saying about service status, and clearly an issue with their exchange/infrastructure as it's nationwide.
