Fairly new connection, now experiencing packet loss
Rajveer86
I joined Plusnet around a month and a half ago and had a line fault which has been resolved (speeds up and down doubled and ping reduced, now getting 59Mb down and around 15 Mb up). However I've recently noticed I'm getting packet loss. This started when playing Battlefield 1 (where I warp every now and then), and testing with "ping www.google.co.uk -t" (and www.bbc.co.uk) shows packets are being timed out every now and then. This is affecting my internet usage so could somebody take a look?
rongtw
Fixes: 12
Re: Fairly new connection, now experiencing packet loss
BF1 are you using DX12 or dx11 ?Huh
a lot of friends report Dx12 is bad
Sunzz
I'm using a GTX 1070 the DX12 sucks! when i tried it in battlefield it was super laggy Sad
rongtw
Fixes: 12
Have you set up a TBB graph , it helps to see what happening http://www.thinkbroadband.com/ping/monitors.html
also check your connection at http://speedtest.btwholesale.com/   and do the Further Diagnostic test Smiley
Riotlightbulb
Yes there are a lot of people reporting packet loss at the moment. I contacted plusnet yesterday and showed them my results from my thread ( https://community.plus.net/t5/Fibre-Broadband/War-Thunder-Packet-Loss/td-p/1383255 ) and they admitted it was an internal problem.
Now i am waiting for a responce from them on my thread as promised.
(and i saved the transcript of the conversation so i can prove they admitted it is an internal problem)
Rajveer86
After 2 weeks I still experience issues, here is a graph:
http://www.thinkbroadband.com/ping/share/3f268cef4c3bc6814a3807e5ee61de79-24-11-2016.html
I get dropped packets too, just not in the graph above.
Rajveer86
I'm still getting latency issues and disconnects:
http://www.thinkbroadband.com/ping/share/9c17175b12cec3ba411a3ea1e0d402e0-29-11-2016.html
PLUSNET ARE YOU THERE?!?
Fixes: 86
Rajveer86 wrote:
... testing with "ping www.google.co.uk -t" (and www.bbc.co.uk) shows packets are being timed out every now and then. This is affecting my internet usage so could somebody take a look?
Google's a bad destination to try this to as they're know to rate limit ICMP probes. You'd be better off trying to somewhere like pingbox1.thinkbroadband.com instead.
Would also b useful to know if you're reliant on a wired or wireless connection?
We have recently experienced some wide-spread packet loss issues, but we're of the opinion that they're now resolved (as of last week).
With the exception of some ever so slight red blips towards the left, that graph shows no sign of issues at all. In fact it looks significantly better than average! Your minimum and average latency looks to be lower than 10s!?
Again, there are no signs of latency problems shown there. Take a look at some other customers' graphs and you'll see what I mean. I'd expect the vast majority of customers' lines to be a lot 'noisier' than yours, similar would apply regardless of the ISP you're with.
Admittedly, the 'blips' early hours do look a bit unusual. The drop (vertical red line) will almost certainly be BT Wholesale maintenance though looking at the time it occurred.
