Failt found on broadband
- Failt found on broadband
05-04-2015 1:27 PM
Re: Failt found on broadband
05-04-2015 5:08 PM
05-04-2015 5:23 PM
06-04-2015 10:36 AM
Our testing isn't showing any issues with the connection and based on the information you've provided it looks like you connect over wireless?
Do you get the same issues over a wired connection?
06-04-2015 11:45 AM
06-04-2015 11:51 AM
06-04-2015 4:35 PM
The second speedtest you've attached shows that it was run over wireless?
Were there any programs running in the background?
06-04-2015 5:10 PM
06-04-2015 5:13 PM
06-04-2015 5:19 PM
Once you've got the test result you can go back to using wireless.
06-04-2015 5:23 PM
06-04-2015 5:51 PM
06-04-2015 6:43 PM
Your best option is to purchase either a better router or try using powerline network adaptors.
Personally I use an Asus RT-N56U router.
06-04-2015 6:55 PM
06-04-2015 6:58 PM
