Failed FTTC install, but ADSL2+ sync with no PPP
wayyoung
Hi all.
Just wondering if anybody had suffered a similar failed install as I did on Monday?
ADSL2+ upgraded to FTTC. Line syncs (Hub1 into master socket) on ADSL2+ still after numerous factory resets. No PPP connection at all. No VDSL sync.
Engineer is currently working the line. Any thoughts or ideas?
wayyoung
Re: Failed FTTC install, but ADSL2+ sync with no PPP
For info it turned out to be a miss wiring at the DSLAM in my cabinet.
Plusnet Staff
Plusnet Staff
Fixes: 117
It looks like it was a jumpering problem at the cabinet, from the engineer notes. Tests are showing the circuit in sync at 80/20. Able to setup the PPP now?
+Edit+
I didn't see your reply before I posted this.
From when I joined the Plusnet Help Team in May 2017 my main Community account is @Gandalf.
 Plusnet Staff
wayyoung
PPP connection established immediately after syncing.
I had to rush back to work but it appeared to have a healthy sync rate. Will test it later and probably swap out the Hub1 as it's sitting precariously on a window ledge for testing purposes and see what we've got here.
We finally seem to have got there in the end after 2 1/2 months and I hope it's the end of all these troubles.
Now...if I could only sort out all the other world problems life would be good indeed :-)
Plusnet Staff
Plusnet Staff
Fixes: 117
Awesome, I'm happy to hear it.
Aye, it's been quite a journey! Glad to see you're getting a massive boost in speed now on this cabinet.
 Plusnet Staff
wayyoung
and with a bit of headroom to spare
  Upstream Downstream
Current Rate (Kbps) 19999 79995
Max Rate (Kbps) 38157 103846
SNR Margin (dB) 23.2 13
Line Attenuation (dB) 10.1 10.3
Errors (Pkts) 0 0
Thanks again for all your help.
Be well ;-)
Browni
Aspiring Hero
Fixes: 47
Nice!
I must have been really bad in a previous life as this was my 3rd ISP in a row that used lithium.
Now you're stuck with me because my new ISP doesn't run a forum Cheesy
Plusnet Staff
Plusnet Staff
Fixes: 117
Success. No problems, I'm happy to have helped you through this. Smiley
If there's ever anything else I can help with please just let me know.
 Plusnet Staff
jafreer
What fantastic line stats. You must be sitting on top of the cabinet! Look at those SNRMs. Jealous!
wayyoung
I guess I'm between 150-200m from the cabinet but I haven't seen the estimates from any line tests as yet.
Plusnet Staff
Plusnet Staff
Fixes: 117
Line length is sitting at around...
Estimated Line Length In Metres 243.6
 Plusnet Staff
wayyoung
It's amazing how long a line actually is compared to how long you think it may be, or think it needs to be.
