Factory reset on Technicolour 582n and now can't log in
- Factory reset on Technicolour 582n and now can't l...
27-11-2015 7:16 PM
My son (honestly) has tried to change the password for our Technicolour router, but mucked up. We can no longer log in. So we thought a factory reset would fix this, but since we have done that we cannot login using the CPXXXXXXXX serial number either.
Message 1 of 3
(1,117 Views)
2 REPLIES 2
Re: Factory reset on Technicolour 582n and now can't log in
27-11-2015 8:31 PM
After your factory reset, when you now open your computer's web browser (e.g. Internet Explorer, Safari or Firefox etc.) what exactly do you see:
a) The Broadband Setup page or
b) The Technicolor Login Screen?
Professionals are predictable - it's the amateurs that are dangerous!
Message 2 of 3
(820 Views)
27-11-2015 8:37 PM
good luck with that as i found i had to change over to my brand new personally bought router since i lost internet connection some nights ago and the router simply couldnt take my password etc.
Message 3 of 3
(820 Views)
