Facetime Poor Connection when using Wi-Fi
- Facetime Poor Connection when using Wi-Fi
27-01-2019 11:52 AM
Hi
I have a TP-Link Archer VR2600 Router that seems to work fine, I have no issues with speed or connection most of the time.
Speed tests show ~65mb down and ~18mb up on both wired and wireless connections.
My wife uses Facetime on an iPhone 7 to chat with her Mother in Holland and both of our kids who are away at University. If she connects to the Wi-Fi to use Facetime and make these calls, to three different people, in three different locations, then she constantly gets "Poor Connection" messages and no video.
If she switches off Wi-Fi and uses 3G - There are no issues...it works fine...
I have reset the router to factory settings and set the DNS to Google DNS 8.8.8.8 and 8.8.4.4 to see if this would make any difference but the issue still remains.
Does anyone have any ideas on what could be causing this issue?
I'm not sure if the issues is with the Router and something needs to be changed or if it is something on the Plusnet Network?
Michael
Re: Facetime Poor Connection when using Wi-Fi
28-01-2019 8:55 AM - edited 28-01-2019 8:58 AM
Hi @sheavesm,
I'm sorry to hear that you're experiencing connection problems on Facetime when using your WiFi.
I've tested your line and the test hasn't picked up any underlying connection problems from here:
GEA Test Detail | |||
Circuit ID | NA | Service ID | BBEUXXXXXXXX |
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0000 | ||||
Description | GEA service test completed and no fault found . | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 76.6 Mbps | ||||
Upstream Speed | 20.0 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Not Detected | ||||
Radio Frequency Ingress | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Cross Talk | Not Detected | ||||
Estimated Line Length In Metres | 343.8 | ||||
Upstream Rate Assessment | Very Good | ||||
Downstream Rate Assessment | Very Good | ||||
Interference Pattern | Regular Interference Observed Daily | ||||
Service Impact | No Impact Observed | ||||
Interference Duration Longest Occurrence | From 12:45 to 02:00 | ||||
Interference Location | Customer Premise | ||||
Interference Observed In Days | 14 | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Technology | VDSL | ||||
Profile Name | 0.128M-80M Downstream 4dB, Retransmission High - 0.128M-20M Upstream, Error Protection Off | ||||
Time Stamp | 2019-01-15T10:00:00 |
As this is the case, it's likely that the problem lies with the WiFi signal from the router. I'd recommend that you have a look at our WiFi connection guide here and that you also try changing the wireless channel on your router (the router's manual should contain instructions on how to do this.)
