Facebook app really slow
- Facebook app really slow
Re: Facebook app really slow
27-06-2017 12:30 PM
ALL: What routers are you using? The white Hub One?
Broadband Service Manager
27-06-2017 12:39 PM
Yep the white hub one for me
27-06-2017 12:53 PM
I will also check with a VPN later.
27-06-2017 1:11 PM
i am using an Asus RT AC66U
27-06-2017 1:18 PM - edited 27-06-2017 1:19 PM
Just in case it helps:
- No problems using a non PlusNet connection on my iPhone.
- On the PlusNet connection at my parents with the HubOne, I hadn't noticed any issues. My sister uses her Facebook quite often the PlusNet connection, and she hasn't mentioned anything is up.
It may be worth trying a soft reset on your iPhone just to see if it makes any difference, I've had problems where it can play up sometimes (e.g. not connecting to public WiFi spots), and it fixed it.
27-06-2017 1:58 PM
27-06-2017 2:10 PM
Ok my parents have the same model of router.
I'll be over there later today, to see if I notice anything.
28-06-2017 12:47 PM
I tried swapping to a VPN (Cyberghost) instead of tunring off wifi and Facebook worked again. At least I won't be burning through my data allowance as much now.
28-06-2017 4:27 PM
I have tested this numerous times and it seems to solve the problem. I'm using IPVanish and have tested a number of endpoints in the UK and across Europe, all work fine.
A friend of mine had the same problem a few months ago and told me that he found a workaround by manually assigning an IP address to his iPhone on his Plusnet home broadband. I will try this and see if it works
28-06-2017 5:39 PM
Pretty sure that the problem is with Plusnet's DNS server. Just changed it on my phone to one of Open DNS's servers (208.67.222.222) and it seems to be working flawlessly now. Would also explain why using a VPN works for other people.
No idea why this would only affect the mobile app, never have any problems with the desktop site.
on
28-06-2017
6:25 PM
- last edited on
01-07-2017
9:05 AM
by
Mav
Scratch that. It's started playing up again.
Moderator's note by Mike (Mav): Full quote of preceding post removed as per Forum rules.
28-06-2017 8:04 PM
I guess the setup using the website would be something like Web browser -> Facebook web server -> Facebook data server. Whereas the app would already have all the layout assets built in and just connect directly the the data server. On the website it would be the web server connecting to the data server, so Plusnet DNS would noted to know about it.
28-06-2017 8:38 PM
Yeah that makes sense. I'm still not sure - Facebook does seem to be being really slow on my desktop tonight aswell, so maybe it's just that. The app definitely seems more responsive since I changed the DNS - almost every time I pressed on "view more comments" before I'd just get the spinning wheel until I turned wifi off, it's working fine most of the time now.
29-06-2017 9:13 AM
Thanks for the hints. We're continuing to look.
30-06-2017 4:02 PM
Same issue is happening for my girlfriend.
She's on iOS (6S), connected to the default Plusnet router via WiFi and it happens within the Facebook app. When she disconnects from WiFi and uses 4G, the issue doesn't occur.
I'm on Android, and the Facebook app works fine for me when connected to WiFi.
