Facebook app really slow
- Facebook app really slow
Re: Facebook app really slow
20-09-2017 4:22 AM
There's also somebody with an Asus router reporting issues (which incidentally is the manufacturer of the router that's 'fixed' things for you)
As Kelly says, we're still looking into it, however it would be interesting to find out whether or not yesterday's iOS update has influenced the situation for anybody?
@Lostk2, I can't send a prepaid returns bag unfortunately. Would normally offer to refund the cost of postage but that might be tricky if your account's already closed ☹️
@lrc123, if you can reliably replicate the issue almost everytime, then I might try and grab some logs from your router during a pre-arranged time when you're able to test if that's OK? (although not confident those logs will show us much).
Another thing people might be able to help us with, although not for the technically uninitiated, would be to sniff and capture the WiFi traffic when this happens using a Mac. It's not straight forward though, and you'd need to capture the iOS device establishing a connection to the access point too, because without the key exchange the data won't be much use.
20-09-2017 9:28 PM
It is still happening on iOS 11.
I am happy to help with logs.
I am also happy to help with sniffing the connection from my Mac, I am technically minded, so would be able to follow instructions.
22-09-2017 12:36 PM
Thanks, that's really helpful of you.
I'm out of the office at present so the remote logging may have to wait. It's not going to catch much more than what's visible in the router helpdesk logs though.
Ditto for capture instructions until I get the opportunity to mess around with it myself.
If you do want to get a head start though, then this looks like it might do the trick. Few things to consider:
- Looks like you might need to fix the wi-fi channel in the Hub One to make sure you're capturing the right traffic.
- Make sure the mac is next to the router when sniffing and that the iOS device is close but you have the mac between the device and the router.
- Disconnect all wireless clients, connect the mac and start the capture.
- Connect the iOS device and try to avoid connecting anything else to avoid unnecessary noise.
- You'll need to replicate the Facebook/iOS issue a few times before stopping the capture.
- Try to keep the capture time to a minimum because the output can get fairly hefty.
- Worth keeping a note of timestamps which will make analysis easier.
- We may need your SSID and WPA-PSK key in order to interpret any results.
If you do manage to give this ago (and I wouldn't expect it of you, so am grateful for the offer), then let me know and we'll arrange a way for you to get the output to me (needless to say, I wouldn't suggest uploading or linking to it here).
23-09-2017 12:27 PM
Aswell as replacing the router i have also moved my router as I read that certain electrical appliances cause havoc with Wi-Fi signals (previously my router was quite close to a fish tank), it's now centrally located in my house on a shelf I made above a door in my pantry. To be fair I never tried the hub one up there.
Could line noise or attenuation be causing an issue with people's connections? I was going to look into getting a new faceplate as the telephone socket in my house is a bit dated and i wanted to see if it was causing an issue, adsl/vdsl microfilters are cheap and nasty, not to mention an eye sore if they're on show
08-10-2017 12:17 PM
Any updates on this issue.
08-10-2017 1:03 PM
Not yet I'm afraid. I've been out of the office these last few weeks. Hoping to make some progress next week when I'm back in.
08-10-2017 11:12 PM
13-11-2017 8:03 PM
13-11-2017 8:10 PM
It seems particularly bad tonight.
14-11-2017 3:45 PM
14-11-2017 4:44 PM
I've had an iPad on my desk for the last few weeks connected to a Hub One that I was hoping to be able to replicate the issue from. No such luck though. Every time I've spent a few minutes using either the Instagram or Facebook apps, I've failed to encounter any issues at all
@lrc123, I don't suppose you managed that traffic capture in the end?
14-11-2017 4:50 PM
No, it looked a bit too involved for me. I've just taken to turning wifi off if I want to use Facebook or Instagram.
Have you been able to tell if the apps connect to a different address to the websites?
27-11-2017 5:30 PM
I’ve got to say that I’m not impressed that so many people are having the same issue and since April it still hasn’t been rectified... I’m running the latest iOS on an iPhone 6s.
Please update ASAP as this is frustrating to say the least.
27-11-2017 5:48 PM - edited 27-11-2017 5:48 PM
14-12-2017 12:40 PM
Is the reason Plus net have gone silent because they cant resolve the issue?
Lots of PlusNet customers are still having this issue
