Facebook and Instagram CDN Reachability Issues
FIXED- Subscribe to RSS Feed
- Re: Facebook and Instagram CDN Reachability Issues
20-01-2020 8:11 PM - edited 20-01-2020 8:13 PM
Hi All,
Just had my Plusnet Fibre activated today. Fairly happy with the activation process and the speed so far. A little slower than BT that I switched from, but I know I'll need to wait for DLM to work its magic.
However, I'm having an issue wherein images and videos won't load on facebook or Instagram on any devices (Laptops, Phones, WiFi or Wired) connected via the new Plusnet connection. This appears to be an issue with reaching a lot of facebook CDN domains (e.g. "scontent-scl1-1.xx.fbcdn.net" amongst others.) It's not a DNS issue as I can resolve that domain to an IP.
If I drop off the Plusnet connection or use a VPN, I can reach this domain fine and facebook and Instagram work as normal. Other web based tools are reporting that domain as being up and reachable. Does anyone have any thoughts as to what the issue could be, or is anyone experiencing a similar issue?
Fixed! Go to the fix.
20-01-2020 8:16 PM
Welcome aboard @davidmhewitt
I'm sorry to see you're having issues loading Facebook and Instagram. Assuming you're not experiencing any other issues with your connection, could you provide the information from Here so we can investigate further?
20-01-2020 8:40 PM
Thanks @Gandalf , I can confirm that the service is OK other than issues with certain parts of Facebook and Instagram.
- What device (manufacturer, model and OS version) you are using
This issue is persistent across all manner of devices. I've tested a Google Pixel 2 (Android 10), a Dell XPS 13 (Running Ubuntu 18.04) and an iPhone 8 (running iOS 13). So a fair selection to say it's a network issue rather than a device issue.
When you experience the issue what is your IP address
Current IP is 209.93.151.220 and can confirm the issue still exists
Which router (model + software version) you are using. Visit 192.168.l.254 and log into your router to get this information
Currently testing on a Plusnet Hub One | Software version 4.7.5.1.83.8.263 However, the issue is reproducible with a BT HH6 also
If you're able to replicate the issue, would you be happy for us to contact you and run tests on your line whilst you the problem
Yes, since the service was active, this has been reproducible. Happy to be contacted about it.
For further information, here's a traceroute to one of the domains I'm having an issue with:
traceroute to scontent-scl1-1.xx.fbcdn.net (179.60.193.20), 30 hops max, 60 byte packets
1 _gateway (192.168.1.254) 1.717 ms 16.470 ms 16.510 ms
2 * * *
3 * * *
4 128.hiper04.sheff.dial.plus.net.uk (195.166.143.128) 28.728 ms 132.hiper04.sheff.dial.plus.net.uk (195.166.143.132) 29.646 ms 30.496 ms
5 core1-BE1.colindale.ukcore.bt.net (195.99.125.132) 31.797 ms 195.99.125.140 (195.99.125.140) 32.002 ms 32.230 ms
6 194.72.16.60 (194.72.16.60) 32.299 ms peer7-et-3-0-4.telehouse.ukcore.bt.net (109.159.252.160) 17.753 ms 194.72.16.78 (194.72.16.78) 23.577 ms
7 109.159.253.215 (109.159.253.215) 29.627 ms 109.159.253.163 (109.159.253.163) 29.367 ms 109.159.253.215 (109.159.253.215) 29.517 ms
8 * * *
9 ae121.ar01.lhr6.tfbnw.net (157.240.40.68) 30.391 ms ae121.ar01.lhr3.tfbnw.net (129.134.44.166) 29.702 ms ae124.ar01.lhr6.tfbnw.net (129.134.34.224) 24.267 ms
10 ae6.bb02.lhr8.tfbnw.net (129.134.43.184) 24.330 ms 24.529 ms 24.483 ms
11 ae26.bb02.dub1.tfbnw.net (129.134.47.102) 30.651 ms ae14.bb02.bos2.tfbnw.net (31.13.24.156) 92.661 ms ae4.bb01.bos2.tfbnw.net (157.240.32.192) 90.499 ms
12 ae15.bb02.lga1.tfbnw.net (157.240.42.179) 93.339 ms 93.213 ms 93.108 ms
13 ae41.bb04.dca1.tfbnw.net (204.15.23.208) 105.342 ms ae45.bb03.dca1.tfbnw.net (74.119.78.216) 93.574 ms ae10.bb01.dca1.tfbnw.net (157.240.53.212) 100.670 ms
14 ae26.bb03.clt3.tfbnw.net (157.240.42.54) 117.764 ms ae25.bb01.clt3.tfbnw.net (129.134.37.70) 115.492 ms ae26.bb03.clt3.tfbnw.net (157.240.42.54) 121.081 ms
15 * * *
16 * * *
17 * * *
18 * * *
19 * * *
It times out after this point.
21-01-2020 10:37 AM
Are you having issues using those sites via a browser, or via the Apps? (Or both?)
Ex-Broadband Service Manager
21-01-2020 1:29 PM
21-01-2020 2:01 PM
I should add that I've cleared the cache in affected browsers and tried re-installing the app on a phone. This has had no effect on the issue.
The majority of the functions within facebook and Instagram work fine. For example, I can sign out and and in again and new posts can be loaded and I can read any text associated with them. Just any images or videos that would ordinarily be fetched from facebook CDN domains never load and eventually time out.
As I said in an earlier post, it doesn't seem to be a DNS issue as I can resolve the IP address of these CDN domains when connected via the plusnet connection (using either plusnet DNS or another provider, e.g. cloudflare). My devices just can't make a connection to these domains, almost as if there's a routing issue somewhere between my router and wherever these facebook CDNs are peered.
Also proven that this isn't an issue with my router by trying a BT HH6 that I've configured myself as well as the Plusnet provided router as configured out of the box. The problem is exactly the same with both.
21-01-2020 4:26 PM
hang on, are you saying the images never load? or is it intermittent and only fails sometimes?
21-01-2020 4:51 PM
21-01-2020 5:16 PM
Hi, I've applied a static IP to your account. This is just to change a bit of how your traffic routes through the network. I want to see if it changes the behaviour. Can you restart your router and see if it still happens? We've not come across this before.
21-01-2020 5:28 PM
21-01-2020 5:30 PM
Yeah, please do!
21-01-2020 5:57 PM
The traceroute below shows how the particular facebook domain I was having issues with is now reachable:
traceroute to scontent-scl1-1.xx.fbcdn.net (179.60.193.20), 30 hops max, 60 byte packets 1 _gateway (192.168.1.254) 4.773 ms 4.514 ms 4.495 ms 2 84.93.253.88 (84.93.253.88) 21.009 ms 21.989 ms 21.974 ms 3 84.93.253.95 (84.93.253.95) 23.058 ms 23.530 ms 23.521 ms 4 195.99.125.136 (195.99.125.136) 21.922 ms 21.902 ms 195.99.125.144 (195.99.125.144) 22.985 ms 5 62.172.103.232 (62.172.103.232) 23.461 ms peer2-et-3-0-4.slough.ukcore.bt.net (109.159.252.122) 23.962 ms peer3-et-0-0-1.redbus.ukcore.bt.net (62.172.103.238) 23.432 ms 6 ae20.pr04.lhr3.tfbnw.net (157.240.64.6) 44.781 ms 109.159.253.217 (109.159.253.217) 30.136 ms ae20.pr04.lhr3.tfbnw.net (157.240.64.6) 49.985 ms 7 * * * 8 ae122.ar01.lhr6.tfbnw.net (157.240.42.150) 20.176 ms ae111.ar01.lhr3.tfbnw.net (129.134.44.164) 20.163 ms ae111.ar02.lhr3.tfbnw.net (129.134.44.168) 22.160 ms 9 ae6.bb01.lhr8.tfbnw.net (129.134.41.30) 21.264 ms ae7.bb01.lhr8.tfbnw.net (129.134.43.186) 22.135 ms 22.123 ms 10 ae26.bb02.dub1.tfbnw.net (129.134.47.102) 30.543 ms ae13.bb02.bos2.tfbnw.net (31.13.28.218) 88.953 ms ae13.bb01.bos2.tfbnw.net (31.13.27.58) 85.793 ms 11 ae25.bb02.lga1.tfbnw.net (173.252.65.225) 97.965 ms ae13.bb01.lga1.tfbnw.net (157.240.42.175) 96.968 ms ae15.bb02.lga1.tfbnw.net (157.240.42.179) 87.381 ms 12 ae29.bb01.dca1.tfbnw.net (74.119.78.214) 93.527 ms ae19.bb03.dca1.tfbnw.net (157.240.53.208) 96.494 ms ae10.bb01.dca1.tfbnw.net (157.240.53.212) 96.455 ms 13 ae25.bb04.clt3.tfbnw.net (31.13.29.184) 111.400 ms ae22.bb01.clt3.tfbnw.net (129.134.37.66) 112.433 ms ae25.bb01.clt3.tfbnw.net (129.134.37.70) 114.519 ms 14 ae0.ar01.scl1.tfbnw.net (31.13.28.233) 222.931 ms ae26.ar02.scl1.tfbnw.net (31.13.27.73) 220.848 ms 223.960 ms 15 ae120.pr02.scl1.tfbnw.net (74.119.76.231) 215.232 ms ae120.pr04.scl1.tfbnw.net (74.119.77.249) 237.445 ms ae120.pr02.scl1.tfbnw.net (74.119.76.231) 216.265 ms 16 po101.psw04.scl1.tfbnw.net (204.15.21.199) 213.898 ms po102.psw01.scl1.tfbnw.net (74.119.79.207) 215.015 ms po101.psw02.scl1.tfbnw.net (204.15.20.191) 218.273 ms 17 173.252.67.159 (173.252.67.159) 220.323 ms 173.252.67.11 (173.252.67.11) 221.531 ms 173.252.67.161 (173.252.67.161) 221.919 ms 18 xx-fbcdn-shv-01-scl1.fbcdn.net (179.60.193.20) 213.030 ms 213.192 ms 215.070 ms
How do we proceed now? I assume having a static IP assigned to my account is a temporary measure? Is this enough information for a fault to be raised internally to look at what was wrong with my original route, or do you require anything further from me?
Thank you for the quick and informed responses so far, however. Yourself and @Gandalf have been very helpful.
21-01-2020 6:06 PM
Hi, not trying to jump on your thread or anything, but can confirm that I have also experienced the same issues with FB intermittently not loading content on all devices since my line went live 15 days ago, so you're not alone.
21-01-2020 9:13 PM
24-01-2020 12:32 PM
Thanks for that. We've raise a ticket internally to see if we can work out why this would be happening. We'll keep you on the static for the minute, but might ask to remove it for some testing at some point. We'll be in touch!
