Facbook comments wont load?
moc247
I've noticed my facbook wont load comments when attached to my plusnet but if I switch to my mobile wifi or connect to my neighbours wifi it's fine what can I do?
1 REPLY 1
TedT
Re: Facbook comments wont load?
HI Moc and welcome,
Thanks got reaching out and I'm sorry its under such circumstances.Having had a look over your connection it apprears your likely suffering from Wireless interference. With the level of usage recorded that would not be possible with any fault on your line.
I will send over some handy hints and tips on wireless settings that are likely to help you improve that experience.
You can find help with your wifi connection here: http://goo.gl/BxgTFB
Regards
Kev
 Kevin T
