FTTP in Poundbury?
watsonm
FTTP in Poundbury?
Am in the process of moving house and one possible option is in the Duchy of Cornwalls estate of Poundbury. (Dorset)
I see most of the newer houses are cabled up for FTTP and wonder if anyone is using this with Plusnet or do I have to (or can I ) connect up my VDSL modem to the phone line and run FTTC as before.
Thanks for any input.... Mike
Plusnet Fibre 80/20 Netgear R7000 and Netgear DM200
Plusnet customer since 2002
Plusnet Mobile since 2017
3 REPLIES 3
Fixes: 93
Re: FTTP in Poundbury?
Plusnet do not have a FTTP product since they closed the trial. You cannot use a VDSL set up unless you can also get a FTTC service, which is highly unlikely at a FTTP serviced new build. Bite the bullet and move into the 21st century, be it with a different ISP!
Edit
You could still use your R7000 router
watsonm
Thanks for the reply Baldrick1, obviously not what I wanted to hear.... FTTC was fine over in the wilds of Exmoor running at 65/17 and I have(had)  a non trivial referral count!!
watsonm
(Also posted on thinkbroadband forum)
Did a BT line checker on the post code today.
https://ibb.co/Wgdjhvm
Does the "other Offerings" line saying VDSL Multicast "available" imply I might get VDSL ....?
As a retired couple on a pension we don't really need or want to pay for 330 Mbps download . I know I can pay for lower speeds but I am still trying to preserve my Plusnet Referrals!! smile
If the answer is in the positive do I need to push Plusnet into providing VDSL or will they just look at the FTTP line and say "No we can't suppply"
Thanks Mike
Moderator's note by Mike (Mav): Post released from Spam Filter.
