FTTC upload speed consistently below 1Mbps
- FTTC upload speed consistently below 1Mbps
13-10-2014 11:02 AM
I have had this problem for some weeks, as well as a good number of service losses (setting aside major network problems recently).
Thought problems might be down to the Plusnet supplier router, so switched in a Netgear Nighthawk R7000. Has not made any difference.
I reset the BT Openreach modem (had to anyway over the weekend) and plugged in a fully reset Plusnet router to it using default settings. Connected both a phone and a Macbook pro a different times, and test result was pretty much the same using Speedtest.net and the Thinkbroadband speed test. Do not have an ethernet port on my laptops, so cannot do a direct PPoE connection to the VDSL modem.
How do I get the line checked?
Message 1 of 7
(1,971 Views)
6 REPLIES 6
Re: FTTC upload speed consistently below 1Mbps
13-10-2014 11:06 AM
Those results look really odd
Can you run the BT Speedtest and then Further Diagnostics
Also run the TBB test again but with your security package disabled
Message 2 of 7
(1,501 Views)
13-10-2014 11:28 AM
Cannot run the BT speedtest as I do not have an ethernet port on my Macbook Pro. Tried with a USB to Ethernet adapter but did not work. Have ordered a Thunderbolt to ethernet adaptor which should arrive tomorrow.
I have run the tests again, making sure no additional security is turned on in OS X.
Only one device is connected, this one.
Message 3 of 7
(1,501 Views)
13-10-2014 11:31 AM
Run the BT speedtest via wireless as it is the Further Diagnostics which would be interesting - it should give an upstream IP profile of 20Mbps
Message 4 of 7
(1,501 Views)
13-10-2014 11:43 AM
Borrowed my wife's laptop, connected via USB to ethernet port to my router.
Further diagnostics:
Quote Upload speed achieved during the test was - 0.42Mbps
Additional Information:
Message 5 of 7
(1,501 Views)
13-10-2014 11:51 AM
Have you raised a fault at https://faults.plus.net as something is seriously adrift with the BT systems
Message 6 of 7
(1,501 Views)
13-10-2014 12:14 PM
I have now. Thanks for your help Oldjim.
Message 7 of 7
(1,501 Views)
