FTTC router optional?
- FTTC router optional?
- « Previous
- 1
- 2
- Next »
Re: FTTC router optional?
03-07-2012 7:59 PM
Do you actually understand what the difference is between a wireless router and a wireless access point?
03-07-2012 8:08 PM
I'd keep the new router and keep the old one as a spare (with the FTTC firmware flashed so it's 'ready to go' if needed.
03-07-2012 9:05 PM
Quote from: jelv Do you actually understand what the difference is between a wireless router and a wireless access point?
I have stated wireless access points to include those wireless access points which support ethernet WAN. It's fairly obvious that I will require a device with ethernet WAN.
A wireless router can be a multitude of devices.
03-07-2012 10:48 PM
The existing 'router' you have performs the following functions:
[list type=decimal]
Those are all the functions you need to connect multiple devices (including wireless) to the internet and this is what the existing 'router' you have does with the existing firmware.
When you convert to FTTC you get a BT modem. This does function 1 ONLY. You can connect a single PC to it's ethernet port when the PC is given your public Plusnet allocated IP address. Alternatively you can connect what is commonly called a cable router which does functions 2 and 3 and optionally function 4 if it is wireless.
The TG582n provided by Plusnet for FTTC is functions 2,3 and 4 in one box. To do this one of the LAN ports is converted to a WAN port which you connect to the modem.
A simple WAP does function 4 ONLY. It has one ethernet port which connects to the LAN. When the TG582n is reconfigured as a WAP in bridge mode it also has multiple LAN ports so it is doing both functions 3 and 4. It does NOT do function 2 so that needs to be done by some other device. You can plug this in to one of the LAN ports on another 'router' or switch. This is often used with a long ethernet cable to get a good wireless connection in another part of the building.
There are other options and configurations, but I've left them out to just cover what you need to understand.
03-07-2012 11:36 PM
I think I've been calling routers, wireless access points and this is where I've been confused. For example the Apple AirPort Extreme Base Station is shown as a wireless access point yet am I right in thinking this is a router (minus modem).
03-07-2012 11:39 PM
04-07-2012 12:05 PM
One thing which has bugged me for some years is the reference to a modem. Those of us old enough remember dial-up at 56kbps know that a modem is shorthand for Modulator/Demodulator i.e. it converted a modulated analogue signal to digital and vice versa. Now, I am sure that many will correct me if I am wrong, ADSL & FTTC are digital signals, the so-called modems therefore are not. What is to be made of this?
04-07-2012 1:11 PM
So IMO modem is fine
04-07-2012 1:31 PM
Quote from: knowdice But the BT telephone line is analogue even for FTTC.
So why is it called an Asymmetric Digital Subscriber Line ?
04-07-2012 1:49 PM
So the device at each end needs to demodulate those tones to produce the digits.
Yes, it's Asymmetric Digital Subscriber Line but I would contend that on the line it's analogue...
29-07-2015 6:51 PM
How many more tones does VDSL add?
29-07-2015 6:55 PM
29-07-2015 7:00 PM
- « Previous
- 1
- 2
- Next »
