FTTC now back to maximum rate
- FTTC now back to maximum rate
21-09-2018 1:04 AM
Hi PN
Finally at last my FTTC is now back to 80Meg
adsl info --stats adsl: ADSL driver and PHY status Status: Showtime Last Retrain Reason: 0 Last initialization procedure status: 0 Max: Upstream rate = 27477 Kbps, Downstream rate = 80703 Kbps Bearer: 0, Upstream rate = 19999 Kbps, Downstream rate = 79999 Kbps Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps Link Power State: L0 Mode: VDSL2 Annex B VDSL2 Profile: Profile 17a TPS-TC: PTM Mode(0x0) Trellis: U:ON /D:ON Line Status: No Defect Training Status: Showtime Down Up SNR (dB): 6.4 15.1 Attn(dB): 11.9 0.0 Pwr(dBm): 12.5 0.9 VDSL2 framing Bearer 0 MSGc: -6 26 B: 243 237 M: 1 1 T: 0 42 R: 10 16 S: 0.0971 0.3781 L: 20922 5374 D: 8 1 I: 254 127 N: 254 254 Q: 8 0 V: 0 0 RxQueue: 63 0 TxQueue: 21 0 G.INP Framing: 18 0 G.INP lookback: 21 0 RRC bits: 0 24 Bearer 1 MSGc: 186 -6 B: 0 0 M: 2 0 T: 2 0 R: 16 0 S: 5.3333 0.0000 L: 48 0 D: 3 0 I: 32 0 N: 32 0 Q: 0 0 V: 0 0 RxQueue: 0 0 TxQueue: 0 0 G.INP Framing: 0 0 G.INP lookback: 0 0 RRC bits: 0 0 Counters Bearer 0 OHF: 0 183692 OHFErr: 0 0 RS: 29989112 3416690 RSCorr: 8 0 RSUnCorr: 0 0 Bearer 1 OHF: 45510 0 OHFErr: 0 0 RS: 546117 0 RSCorr: 1 0 RSUnCorr: 0 0 Retransmit Counters rtx_tx: 144265 0 rtx_c: 4 0 rtx_uc: 0 0 G.INP Counters LEFTRS: 0 0 minEFTR: 79975 0 errFreeBits: 891822 0 Bearer 0 HEC: 0 0 OCD: 0 0 LCD: 0 0 Total Cells: 112459016 0 Data Cells: 16603618 0 Drop Cells: 0 Bit Errors: 0 0 Bearer 1 HEC: 0 0 OCD: 0 0 LCD: 0 0 Total Cells: 0 0 Data Cells: 0 0 Drop Cells: 0 Bit Errors: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 AS: 730 Bearer 0 INP: 48.00 0.00 INPRein: 0.00 0.00 delay: 0 0 PER: 0.00 3.98 OR: 0.01 64.22 AgR: 80080.38 20063.54 Bearer 1 INP: 4.00 0.00 INPRein: 4.00 0.00 delay: 3 0 PER: 16.06 0.01 OR: 95.62 0.01 AgR: 95.62 0.01 Bitswap: 0/0 0/0 Total time = 12 min 10 sec FEC: 8 0 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Latest 15 minutes time = 12 min 10 sec FEC: 8 0 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Previous 15 minutes time = 0 sec FEC: 0 0 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Latest 1 day time = 12 min 10 sec FEC: 8 0 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Previous 1 day time = 0 sec FEC: 0 0 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Since Link time = 12 min 9 sec FEC: 8 0 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 >
Message 1 of 3
(687 Views)
2 REPLIES 2
Re: FTTC now back to maximum rate
21-09-2018 2:31 PM
I am pleased to hear that your speed is back up to 80meg.
Please let us know if you have any further queries.
Thank you,
Aisha
Message 2 of 3
(633 Views)
22-09-2018 12:35 PM
It's appear that dsl checker for my address has changed from btwholesale email alert me. Look like the cabinet is full.
Changed:
- VDSL Range A (Clean) 80 70.1 20 19 63.4 Available --
- VDSL Range B (Impacted) 80 62.8 20 19 51.1 Available --
... into:
+ VDSL Range A (Clean) 80 70.1 20 19 63.4 Waiting list --
+ VDSL Range B (Impacted) 80 62.8 20 19 51.1 Waiting list --
Added:
+ This PCP has a waiters list for FTTC VDSL services. You may place an
+ order which will be dealt with in turn.
Changed:
... into:
Added:
Message 3 of 3
(610 Views)
