FTTC down/up speed asymmetry
oldtimer
What determines the download/upload ratio? I've noticed other FTTC
users get more balanced ratios. Examples:
http://community.plus.net/forum/index.php/topic,136655.msg1199032.html#msg1199032
- down/up ratio ~5:1
http://community.plus.net/forum/index.php/topic,136670.0.html
- 3:1
Plusnet help page:
http://www.plus.net/support/broadband/speed_guide/broadband_speeds.shtml
Fibre 'up to' 76Mb/s up, 19.5Mb/s down
- 4:1
Our speeds here reported by speedtest.net and speedtest.btwholesale.com
are around 8.96 down/0.38 up - a ratio of around 24:1
There's just over a mile of copper from the street cabinet which
explains the slow download speed, but what is stopping the upload from
being closer to 2Mbit?
Current package is Plusnet Unlimited Fibre
9 REPLIES 9
Fixes: 62
Re: FTTC down/up speed asymmetry
It is governed by the line length and quality http://www.thinkbroadband.com/guide/fibre-broadband.html gives an indication although individual lines can have different characteristics
sjptd
I think the upload tones are lower frequency than the download tones, so some forms of noise (near audio frequency) will have a much greater impact on upload.
It could also be caused by poor filters; shouldn't be the case with a standard install and filtered faceplate, but ...
Or a mild case of star wiring, with some sort of extension coming off a junction box in the incoming feed before it reaches the master socket.
If you've got an unlocked modem a program such as dslstats will show the tones and might give more clue.
Stoker
Quote from: sjptd
It's a bit more compicated than that (assuming my spectrum is typical): red is downstream and green is upstream
Fixes: 4
And one from mine (around 450m from cabinet)
Call me 'w23'
Fixes: 4
post removed- something caused quote of above.
Call me 'w23'
sjptd
Thanks Stoker and w23:
I had thought that the upload and download tones were now more overlapping than they used to be on ADSL, but a quick trip to DSLStats indicated that they were not.
I have now made another check, and see that my DSLStats was set up only to display a small proportion of all tones.
I have now moved the Compress/Expand slider and can see the full picture, and my graph is similar to w23's with three upload tone ranges.
Stoker
I'm about 850m from the cabinet, with some aluminium wiring too, so I don't get anything above tone #2000.
oldtimer
Thanks for all the info.
Stoker, w23, sjptd - How are you generating those frequency charts?
I'm almost certain we've got a single copper pair back to the green box... but much of line is above ground, passes through trees and hedges, has probably been there since the 1970s and has been repaired and patched many times.
As far as I know, it's not possible to get much in the way of stats from the modem as it can't be accessed through the Plusnet supplied Thomson/Technicolor TG582n router.
...and download has jumped up to 11.4Mbps in the last week but upload is still around 0.39Mbps.
Very frustrating.
I was wondering if our DECT phones might be causing a problem, but they run at GHz frequencies, so it seems unlikely.
Fixes: 4
Unlocked (Huawei HG612 only) BT modems have accessible stats, mine come from my all-in-one router (AVM Fritz Box 7390).
Call me 'w23'
