FTTC *does* work for some of us, honest!
- Re: FTTC *does* work for some of us, honest!
17-01-2018 1:33 PM
With all the issues that get posted her, I think it's worth highlighting that, for many of us, FTTC actually works pretty well.
When I signed up to PlusNet, around 18 months ago, I had to start with ADSL, then quickly moved to FTTC. My line speed was initially around 65 meg. In the last 6 months, it has actually moved to over 70 meg.
My actual data throughput varies: most of the time it is very good, but occasionally there's a bit of a slowdown, caused by congestion somewhere along the line: that is normal and to be expected. But typically, even in the middle of the working day, the performance is usually very good.
The only negative is that, occasionally (and, of course happens at the most inconvenient time!) the line / router will decide that it's time to "resync my line": typically this is late on a Monday morning, a couple of hours into an online training session that I am hosting! (do others get this too? can I change the time when it wants to do the resync?)
Of course, not many of use will report that things are working just fine, so all you see here are problems, but I suspect, in reality, the problems are very much in the minority (although I fully realise that doesn't help when you are the one with the issue!!!!)
17-01-2018 3:26 PM
Thanks for taking the time to post, I'm glad to hear you're happy with the service.
Our tests aren't finding the cause of why your connection is dropping late mornings.
Description | GEA service test completed and no fault found . |
Sync Status | In Sync |
Downstream Speed | 74.9 Mbps |
Upstream Speed | 19.1 Mbps |
Voice Line Test Result | Pass |
The tests are picking up on potential interference though...
Interference Pattern | Regular Interference Observed on Week Days |
Service Impact | Retrains Observed |
Interference Duration Longest Occurrence | From 11:15 to 11:30 |
Interference Location | Unknown |
Is there anything near your router that might be on a timer?
