FTTC advice please
- Re: FTTC advice please
FTTC advice please
13-04-2015 7:56 PM
Anyone any good with lines stats who can tell me if these stats look right for the speed I'm getting (and also what type of cab it looks like I'm connected to from the band info?)
When I first went for FTTC I was expecting better connection speeds than what I got. Looking at the poles, etc I estimate I'm about 150-200m from the FTTC cabinet, and from there to the local exchange is around 400m for approx 600m total.
These are the line stats I'm getting. Based on these stats would you expect a better speed or is the speed I'm getting looking correct for the stats/distance estimates above?
Welcome Visiting Huawei Home Gateway
Copyright by Huawei Technologies Co., Ltd.
Login:admin
Password:
ATP>sh
BusyBox v1.9.1 (2010-10-15 17:59:06 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
# xdslcmd info --pbParams
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 0
Max: Upstream rate = 12399 Kbps, Downstream rate = 41904 Kbps
Path: 0, Upstream rate = 12373 Kbps, Downstream rate = 42051 Kbps
Discovery Phase (Initial) Band Plan
US: (0,95) (880,1195) (1984,2771)
DS: (32,859) (1216,1959) (2792,4083)
Medley Phase (Final) Band Plan
VDSL Port Details Upstream Downstream
Attainable Net Data Rate: 12399 kbps 41904 kbps
Actual Aggregate Tx Power: 6.9 dBm 12.5 dBm
VDSL Band Status U0 U1 U2 U3 D1 D2 D3
Line Attenuation(dB): 1.2 31.3 40.3 N/A 13.6 40.5 53.5
Signal Attenuation(dB): 1.2 30.7 40.2 N/A 13.6 40.5 53.5
SNR Margin(dB): 6.2 6.2 6.1 N/A 5.8 5.9 6.0
TX Power(dBm): -3.6 -14.8 6.4 N/A 10.7 7.2 -0.3
# xdslcmd info --show
Status: Showtime
Retrain Reason: 0
Max: Upstream rate = 12360 Kbps, Downstream rate = 41904 Kbps
Link Power State: L0
Mode: VDSL2 Annex B
VDSL2 Profile: Profile 17a
TPS-TC: PTM Mode
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 5.9 6.1
Attn(dB): 0.0 0.0
Pwr(dBm): 12.5 6.9
VDSL2 framing
Path 0
B: 239 238
M: 1 1
T: 64 32
R: 0 16
S: 0.1816 0.6146
L: 10571 3319
😧 1 1
I: 240 255
N: 240 255
Counters
Path 0
OHF: 2040504 605492
OHFErr: 13 12
RS: 0 82896
RSCorr: 0 57
RSUnCorr: 0 0
Path 0
HEC: 13 0
OCD: 0 0
LCD: 0 0
Total Cells: 480165831 0
Data Cells: 7995614 0
Drop Cells: 0
Bit Errors: 0 0
ES: 12 11
SES: 0 0
UAS: 22 22
AS: 5954
Path 0
INP: 0.00 0.00
PER: 2.90 9.83
delay: 0.00 0.00
OR: 68.82 21.15
Bitswap: 1107 1466
Login:admin
Password:
ATP>sh
Status: Showtime
Retrain Reason: 0
Status: Showtime
Retrain Reason: 0
Mode: VDSL2 Annex B
TPS-TC: PTM Mode
Trellis: U:ON /D:ON
Down Up
SNR (dB): 5.9 6.1
Attn(dB): 0.0 0.0
Pwr(dBm): 12.5 6.9
VDSL2 framing
Path 0
B: 239 238
M: 1 1
T: 64 32
R: 0 16
S: 0.1816 0.6146
L: 10571 3319
😧 1 1
I: 240 255
N: 240 255
Counters
Path 0
OHF: 2040504 605492
OHFErr: 13 12
RS: 0 82896
RSCorr: 0 57
RSUnCorr: 0 0
Path 0
HEC: 13 0
OCD: 0 0
LCD: 0 0
Drop Cells: 0
Bit Errors: 0 0
ES: 12 11
SES: 0 0
UAS: 22 22
AS: 5954
Path 0
INP: 0.00 0.00
PER: 2.90 9.83
delay: 0.00 0.00
OR: 68.82 21.15
Bitswap: 1107 1466
Message 1 of 2
(510 Views)
1 REPLY 1
14-04-2015 11:08 AM
To my comparatively untrained eye your attenuation (at the higher bands anyway) looks high for the distance you believe you are from the cabinet hence your speeds are low for that distance.
The band plan appears to confirm you're on an ECI cabinet.
Call me 'w23'
Message 2 of 2
(279 Views)
