FTTC - Same attenuation, Same SNR, vastly different speeds
- Re: FTTC - Same attenuation, Same SNR, vastly diff...
05-02-2020 8:15 PM - edited 05-02-2020 8:15 PM
Hello,
Had BT engineer round 3 times in 3 months. Speed below min standard on each occasion. They get it just above the min - 32 Mb then it drops back again a few weeks later. 80/20 FTTC plan. Had c50Mb down for 2 years then this.
Screen shots below show same attenuation, same SNR but the Sync speed has gone from 47Mb to 33Mb.
Any ideas what the issue might be?
Re: FTTC - Same attenuation, Same SNR, vastly different speeds
06-02-2020 8:55 PM
07-02-2020 9:46 AM
Many thanks - I have replied on the ticket as requested.
The engineer notes tell the story - something wrong but no idea what.....hence looking for ideas on the forum
10-02-2020 10:01 AM
Hi Kankali,
I'm glad to see that particular engineer has left notes for anyone else picking it up advising what cables to check, that's really helpful.
I've rejected a clear on the fault but it's not in the right status for us to book an engineer visit at the moment. It should be later today so I'll check back on this for you.
10-02-2020 3:13 PM
09-03-2020 9:31 PM - edited 09-03-2020 9:32 PM
Hi
Line seems better but it appears I am now capped at 35,000Kb - despite the router showing it could go faster. Evertime it resyncs it is exactly at that value, no more or less.
BTW the issue appears to be that all the available underground lines into the village are under the Open Reach min commit of 32Mb
14-03-2020 11:21 AM
@kankali. Sorry to hear about the issues you're having with the speed of the service.
It seems that the connection is banded:
I've made sure that this is within the correct area to deal with this and provided an update on the account.
